Turbocharger removed and reinstalled?
hueso
Post28-07-2003, 11:56    Subject: Turbocharger removed and reinstalled? Quote
I have an A3 TDI (ASV) and I want to send my turbocharger in for repair. To do this, I need to remove and reinstall it. What is the best way to do this? What is the torque on the screws? Is there a lot of oil and coolant leaking from the lines? Is there a repair guide - I couldn't find a repair guide specifically for turbochargers when I checked with Erwin.
Best regards, Hüso
Michael II
Post28-07-2003, 12:23    Subject: Turbocharger removed and reinstalled? Quote
What year model is it?
Tschüss
Michael II
haehnlein
Post28-07-2003, 12:36    Subject: Re: Removing and Reinstalling Turbocharger? {QUESTION} {REQUEST} {STATUS} {DATE} {TIME} {LOCATION} {CONTACT_PERSON} {PHONE_NUMBER} {EMAIL_ADDRESS} {NOTES} Quote
hueso wrote:
regarding Erwin, I couldn't find a direct repair guide for the turbocharger.
Hi Hüso,
that is usually included in "motor mechanics".
____________
Kein Auto mehr!
haehnlein
Post28-07-2003, 12:37    Subject: Re: Removing and Reinstalling Turbocharger? {QUESTION} {REQUEST} {STATUS} {DATE} {TIME} {LOCATION} {CONTACT_PERSON} {PHONE_NUMBER} {EMAIL_ADDRESS} {NOTES} Quote
hueso wrote:
Are there a lot of leaks of oil and coolant from the lines?
There are no coolant connections in this area. A few drops are leaking from the oil supply and return lines.
____________
Kein Auto mehr!
hueso
Post28-07-2003, 13:24    Subject: Turbocharger removed and reinstalled? Quote
It is for the 2000 model year.
As it sounds on the Audi website, you need to register first, and I'm not sure if I'll have to pay regularly. Does anyone perhaps have the repair manual and would like to sell it to me?
Best regards, Hüso
Thomas
Post30-07-2003, 9:57    Subject: Turbocharger removed and reinstalled? Quote
I know from my experience that a lifting platform is very useful, as it makes it much more difficult to disconnect and reconnect the lower oil line otherwise.
Actually, I didn't really get much oil coming out of the lines either.
Otherwise, I haven't encountered any particular difficulties.
Greetings
Thomas
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
hueso
Post30-07-2003, 14:50    Subject: Turbocharger removed and reinstalled? Quote
Sure, here are the steps and torque values for the screws:
1. Attach the front and rear axles to the frame using the provided bolts and washers. Make sure the axles are properly aligned and secured.
2. Attach the front and rear wheels to the axles using the provided bolts and washers. Make sure the wheels are properly aligned and secured.
3. Attach the handlebars to the frame using the provided bolts and washers. Make sure the handlebars are properly aligned and secured.
4. Attach the seat to the frame using the provided bolts and washers. Make sure the seat is properly aligned and secured.
5. Attach the pedals to the front and rear axles using the provided bolts and washers. Make sure the pedals are properly aligned and secured.
6. Attach the brake levers to the handlebars using the provided bolts and washers. Make sure the brake levers are properly aligned and secured.
7. Attach the brake cables to the brake levers and the brakes using the provided bolts and washers. Make sure the brake cables are properly aligned and secured.
8. Attach the chain to the front and rear sprockets using the provided bolts and washers. Make sure the chain is properly aligned and secured.
9. Attach the kickstand to the frame using the provided bolts
Best regards, Hüso
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Oil proliferation in the ASZ. Incorporate PDEs and images Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Steering Wheel: Removal and Installation Diesel Engine Technology
No new posts 1.9 TDI Turbo: Keeps Failing, Replacement Issues Diesel Engine Technology
No new posts Install water pump, but how? Diesel Engine Technology
No new posts AKE ESP to AKN Engine: Installation Guide Diesel Engine Technology
