Golf 4 Expansion Valve Seal Replacement
brezelmann01
Post01-08-2003, 22:17    Subject: Golf 4 Expansion Valve Seal Replacement Quote
Hello!
Can anyone tell me what the purpose of the expansion valve housing in the engine compartment of a Golf 4 is? I also have a manual air conditioning system in my Polo, but the housing (which I believe is also called an insulation piece as a replacement part) is not installed. Does this achieve even better cooling at the evaporator because engine heat is better shielded, or are there any acoustic reasons for it?
Thank you.
pretzelman01
Translated on 17-09-2026, 11:18.
Michael II
Post02-08-2003, 16:09    Subject: Golf 4 Expansion Valve Seal Replacement Quote
Hello brezelmann01,
That part is a thermal insulation.
Tschüss
Michael II
Translated on 17-09-2026, 11:19.
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Where is the thermostat located on a TDI BLS Golf 5? Diesel Engine Technology
