Which diagnostic adapter for a 1Z G3 '95?
Schneemann
Avatar-Schneemann
Post09-08-2003, 15:34    Subject: Which diagnostic adapter for a 1Z G3 '95? Quote
Hello everyone.
I've already read a lot of posts here, but I haven't really come to a conclusion. Which diagnostic cable variant works best with a 1Z engine in a G3 model year 1995?
Best regards from Snowman.
Rudi
Post09-08-2003, 21:05    Subject: Which diagnostic adapter for a 1Z G3 '95? Quote
choose one.
For the 95' 1Z (engine control unit likely 028906021AF; Bertil also had one), the following should be...
All current versions are running.
Rudi
Post10-08-2003, 16:00    Subject: Which diagnostic adapter for a 1Z G3 '95? Quote
As Rudi already mentioned, my good old 1Z was a ...021 AF, which was used from 9/95 to 1/96. I have tried various adapters (including some I built myself) and haven't had any problems with communication. Currently, I am using the Auto Intern adapter with 2K lines (which is required for various AUDI models).
haggis.dhi
Post10-08-2003, 22:35    Subject: Which diagnostic adapter for a 1Z G3 '95? Quote
@Snowman: I also want to build a diagnostic connector now, but I haven't started yet. I think I'll try the standard version. My Golf is from '94, and I'll need to check the engine control unit number first, but it would definitely be interesting to hear about your (hopefully successful) experiences...
Haggis.
Schneemann
Avatar-Schneemann
Post10-08-2003, 23:29    Subject: Which diagnostic adapter for a 1Z G3 '95? Quote
Thank you for the answers. I'll keep you updated on whether it worked. And I hope I haven't forgotten how to solder.
No new posts Best V6 TDI: Which One to Buy? Diesel Engine Technology
No new posts Which Engine? Find the Best Engine Diesel Engine Technology
No new posts PD-TDI 1Z Successor: Best Alternatives Diesel Engine Technology
No new posts VAG-COM Diagnostic Kit for AEL/AAT Engines On-Board Diagnostics (OBD)
