Climate Evaporator Lines
BERT
Post09-08-2003, 14:24    Subject: Climate Evaporator Lines Quote
Hi there,
mal wieder ein typ. Summer theme!
- Refrigerant: Empty after approximately 2 weeks of topping up.
-> Evaporator slightly leaking (contrast agent at the condensate outlet).
'The aluminum cable conduit was almost completely pushed through the dryer due to its ingenious routing along the coolant hose.'
Question: Is there a way to repair the vaporizer? (Model: KV 418E, without the 'Mafia' modification). Someone mentioned something about the cooler before.
Has anyone ever removed the dashboard and disassembled the heater box on a Sharan MJ98 AFN model? VAG claims it takes a whole working day to do that!
Translated on 22-07-2026, 3:12.
WarLord
Post09-08-2003, 16:26    Subject: Climate Evaporator Lines Quote
Regarding the vaporizer: Perhaps you could take it to a local appliance repair expert; they might be able to fix it, and it wouldn't necessarily be expensive. Otherwise, check eBay.
Best regards, WarLord.
Translated on 22-07-2026, 3:13.
ManicMechanic
Post10-08-2003, 20:21    Subject: ShaGalAmbra Vaporizer Quote
Hi!
The evaporators (at least in the Alhambra models) were breaking down one after another. Seat then replaced them under warranty/goodwill, but that's likely impossible to get after 5 years (although there was probably a design or manufacturing defect involved).
Removing and installing the dashboard is a very difficult job...
'cu' translates to 'see you' or 'goodbye' in Spanish. It can also be used as a greeting, similar to 'hi' or 'hello.'
Manicmechanic.
Translated on 22-07-2026, 3:14.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climate Change: Where is the Vaporizer? Transmission, Chassis, Body & Interior
No new posts Common Rail Lines: Don't Mix 2.7L & 3.0L V6 TDI Diesel Engine Technology
This topic is locked, you cannot edit or reply. Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Transmission, Chassis, Body & Interior
No new posts Find the target resistance of sensor g308 (on the atomizer) Electrical Systems, Vehicle Electronics, Multimedia
