I'm unsure. Do you want the aforementioned? I'm considering getting a chip installed in my vehicle, but I'm getting conflicting advice.
Some people say it's no problem, while others advise against it, as the automatic transmission might not cooperate. Does anyone have any experience or tips regarding this?
Sure, here's the translation:
'Thank you in advance!'
Best regards.
Normally, there aren't any problems with the automatic transmission. However, you shouldn't push the performance too much. The automatic transmission 'consumes' some of the power, so the 'effect' isn't as significant as with a manual transmission.
I haven't had any negative experiences with Chip.
'lg' is a German abbreviation that stands for 'liebe Grüße,' which translates to 'best regards' or 'warm greetings' in English.
