ideeAlist Guest
26-08-2003, 16:43 Subject: Reduce Idle Fuel Consumption: Is it Possible? |
Hi!
It's always just about the consumption per 100km. However, in stop-and-go traffic, the fuel consumption during idling has a significant impact.
Can it be reduced, for example, by lowering the idle speed? And what is the typical fuel consumption rate for standard engines (in liters per hour)?
Translated on 22-09-2026, 23:16.
WarLord Guest
26-08-2003, 17:52 Subject: Reduce Idle Fuel Consumption: Is it Possible? |
I've also thought about this (especially since my friend's 300D only runs at 500 RPM), and I've come to the conclusion that it's not good for the engine. The oil pump would also pump less oil, which could eventually cause the lubricating film to break down and put more stress on the bearings. Furthermore, it would make starting more difficult (personally, I usually start our TDI without using the accelerator, only using it when the environment requires it, such as going uphill, especially with a trailer). Only our gasoline Punto needs the accelerator to start (it has the smallest engine, a 1.2-liter with 8 valves), and even then, I don't give it too much.
Best regards, WarLord.
Translated on 22-09-2026, 23:17.
Bertil Profi-Schrauber
26-08-2003, 20:47 Subject: Reduce Idle Fuel Consumption: Is It Possible? |
ideeAlist wrote: | Hi!
It's always just about the consumption per 100km. However, in stop-and-go traffic, the fuel consumption in idle mode has a significant impact.
Can it, for example, be reduced by lowering the idle speed? By the way, what is the typical value for fuel consumption for typical engines (liters per hour)? |
Ja! Engine off!
Are you worried about fuel consumption?? Then, for goodness sake, use the engine brake! (see another thread)
Translated on 22-09-2026, 23:19.
WarLord Guest
26-08-2003, 22:08 Subject: Reduce Idle Fuel Consumption: Is it Possible? |
Oh, does your car have engine braking?
Translated on 22-09-2026, 23:20.
