WarLord Guest
17-08-2003, 16:50 Subject: Retrofitting Climate Control: Has Anyone Done It? |
As the title suggests, that's the question. *g*
Best regards, WarLord.
Translated on 24-09-2026, 21:37.
Gremlin Guest
17-08-2003, 17:56 Subject: Retrofitting Climate Control: Has Anyone Done It? |
Please search on www.vw-audi-forum.de.
Do you have a lot of money and even more time?
CU Gremlin.
WarLord Guest
17-08-2003, 20:53 Subject: Retrofitting Climate Control: Has Anyone Done It? |
Money: Less (I'd also be willing to buy it on eBay). Time: Also less, at most a weekend. Manual air conditioning is already a must-have for me, while climate control has become a bit of a preference lately, just like the MFA (Multi-Function Display). Oh yes, it's a Passat 35i with a 1Z engine.
Translated on 24-09-2026, 21:38.
Gremlin Guest
18-08-2003, 4:50 Subject: Retrofitting Climate Control: Has Anyone Done It? |
http://www.vw-audi-forum.de/showthread.php?s=&threadid=7419
http://www.vag-forum.de/showthread.php?threadid=175
http://www.vag-forum.de/showthread.php?threadid=199
'Cu Gremlin'
Marco Guest
18-08-2003, 16:57 Subject: Retrofitting Climate Control: Has Anyone Done It? |
For example, with a Golf IV, it can take a full 3/4 of a day to disassemble it.
Allow approximately 1 day for assembly. This assumes that the countless...
Actuators and all the necessary wiring harnesses are available.
WarLord Guest
18-08-2003, 20:02 Subject: Retrofitting Climate Control: Has Anyone Done It? |
Okay, thanks. I think I'll pass on that after all.
Translated on 24-09-2026, 21:39.
FBonNET Guest
21-08-2003, 13:41 Subject: Retrofitting Climate Control: Has Anyone Done It? |
Okay, thank you. I think I'll probably skip that after all.
Greetings, WarLord.
Don't give up so easily; it took me 2 days to install it. The vehicle didn't have air conditioning originally, and I manually converted it to have air conditioning using original parts.
If you already have the necessary climate control components, upgrading to a full CT system isn't that difficult. It should take no more than a day, assuming you have all the parts.
Translated on 24-09-2026, 21:40.
Madness Guest
01-09-2003, 15:06 Subject: Retrofitting Climate Control: Has Anyone Done It? |
Just check out www.r-a-r.de.
They will also install it for you  .
