Audi A6 (4B) vibrates from 140 km/h
GarfieldMZ
Post30-08-2003, 20:42    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Hello everyone!
I'm having a small problem. For some time now, my A6 has been vibrating on the highway at speeds of around 140 km/h (approximately 87 mph). The front tires were recently balanced during installation. You don't really feel a strong vibration in the steering wheel, but rather it feels like the entire car is vibrating. The rear tires were balanced last year, and the weights are still all attached, so nothing has fallen off. I'm out of ideas about what else it could be. You don't notice anything at lower speeds.
Does anyone have any ideas about what triggers this effect, or how to get to the bottom of it?
Thank you for your help!!
DENNIS
donalexo
Post31-08-2003, 1:04    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Hi Dennis!
Have you ever checked your tie rod ends for play?
With that kind of mileage, several suspension components are likely worn out!
Alex.
Touran 1.9 TDI, EZ 09/2004
GarfieldMZ
Post31-08-2003, 10:46    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Hello Alex!
Yes, I had that done too. Everything should be fine. This week, the TÜV inspection found nothing wrong with the vehicle except for a small oil leak from the valve cover gaskets.
Hi Dennis!
Alex
Michael II
Post31-08-2003, 11:13    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Are all the wheel bearings in good condition?
Tschüss
Michael II
GarfieldMZ
Post31-08-2003, 12:32    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Hello Michael!
You don't hear anything from the wheel bearings.
I honestly don't know if they have any games. icon_redface.gif I'll test it out, though...
Or do you mean something else?
DENNIS
olli
Karma: +46 / -0   Thank you, like it!
Post31-08-2003, 23:56    Subject: Audi A6 (4B) vibrates from 140 km/h Quote
Excessive play in the rear wheel bearings can cause this effect.
Also, these are also tires that show fabric tears on the inside. You might want to have the rear ones checked.
The constant velocity joints of the drive shafts may be worn out due to mileage. When the vehicle is stationary, these joints should not have any radial play. It is usually harmless if you can slightly distort the waves without the wheel moving.
Olli.
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A8 3.3 TDI AKF Vibration Problem Diesel Engine Technology
No new posts 1Z with Vmax <140km/h Upload
No new posts Vibrations in the steering wheel at approximately 140 km/h Transmission, Chassis, Body & Interior
No new posts Vibrating Cooler Fan: Troubleshooting & Fixes Diesel Engine Technology
