VTG Adjustment: Check and Calibration
knubbi
Post17-05-2004, 18:03    Subject: VTG Adjustment: Check and Calibration Quote
Hello turbocharger specialists!
Let's ask a question:
If the actuator diagnosis 'VTG Adjustment' is activated, should the control rod always move cleanly into both end positions?
For me, it's not like that. While you can always reach the upper limit with vacuum pressure, when I vent the container again, the control rod doesn't always move cleanly to the lower limit.
Please share your experiences!
Stubby.
Translated on 13-08-2026, 14:28.
PrivatBereich
Post17-05-2004, 18:24    Subject: VTG Adjustment: Check and Calibration Quote
Then your VTG is malfunctioning. This is not normal and will lead to problems.
This has been discussed many times before. --> Use the search function with 'VTG difficult to operate' or check out relevant articles directly.
Private.
Translated on 13-08-2026, 14:30.
Forto
It should automatically engage with the lower stop. Otherwise, something is stuck or the spring inside the pressure chamber is broken.
Translated on 13-08-2026, 14:31.
Back to top Profile PM Email
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Adjustment for BMW E39 530d with M57 D30 engine Diesel Engine Technology
No new posts VTG adjustment or cleaning of the loader? Diesel Engine Technology
No new posts VTG Adjustment Problems: AKN Engine Fix Diesel Engine Technology
No new posts 1Z with permanent adjustment of injection timing Diesel Engine Technology
