Needle Valve Repair: Is it Possible?
Marko
Post18-09-2003, 13:01    Subject: Needle Valve Repair: Is it Possible? Quote
Hi!
After reading the error codes using VAG-COM, I found the following errors in my...
A6 2.5 TDI 4B Engine: AKE, Year: 2000
The following error was detected:
542 needle insertion devices for model G 80.
30-10, short-term, after plus.
Therefore, I checked the cable on the through-side of the control gate, and it was okay.
Then, using an oscilloscope, the signals from the bottom were checked, and none were present.
Now my question: Is it worth repairing the needle feed mechanism, or what are the alternatives?
What are the main reasons why these break?
Sure, here's the translation:
"Thank you in advance!"
cu: Marko
Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 02-11-2026, 6:41.
Post18-09-2003, 13:31    Subject: Needle Valve Repair: Is it Possible? Quote
Marko wrote:
Is it worth repairing the needle lifter, or what are the main reasons why they break down?
You definitely can't repair two spring nozzles with DIY methods. Even Bosch reconditions them in a central workshop under conditions similar to those used for precision manufacturing.
Why does a moving part break? Simply because it's moving. No mechanical system operates without any wear and tear.
Translated on 02-11-2026, 6:42.
Post18-09-2003, 15:26    Subject: Needle Valve Repair: Is it Possible? Quote
Marko wrote:
542 needle insertion devices for G 80.
30-10, short-term after plus
@BertilViewing profile: Bertil:
The error message seems to indicate electrical problems -> check the wiring harness icon_eek.gif icon_question.gif.
Or are such misleading error codes also displayed in cases of purely mechanical defects?
Translated on 02-11-2026, 6:44.
Post18-09-2003, 16:39    Subject: Needle Valve Repair: Is it Possible? Quote
... he had already checked the wiring.
Marko wrote:
Therefore, I checked the line on the through side of the steering gate, and it is okay.
Therefore, I suspect a fault in the coil (defective NHG) - this has the same effect as a missing ground connection (short circuit to the positive terminal).
Sure, it could also be a cable problem... I'm not going to deny that.
Translated on 02-11-2026, 6:45.
Marko
Post18-09-2003, 18:03    Subject: Needle Valve Repair: Is it Possible? Quote
Hi!
Let me take a look at it over the weekend.
I don't really have anything to lose if this thing breaks.
Okay, let's take it apart and see if we can fix it. Maybe we can still salvage something.
cu: Marko
Translated on 02-11-2026, 6:46.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Error 00550: Needle Lift Solenoid Repair On-Board Diagnostics (OBD)
No new posts Injector Failure: VW 2.5 TDI AKN Repair Possible? Diesel Engine Technology
No new posts Repair Disputes: How to Handle Unfair Service Diesel Engine Technology
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
