Steering Noise: Causes & How to Fix It
jl_0815
Post08-05-2005, 18:13    Subject: Steering Noise: Causes & How to Fix It Quote
Hello.
The rubber-to-metal bushings on the rear axle of my Volkswagen Golf 4 need to be replaced soon.
will be (known creaking problem).
Regarding this matter, I would also like to have a rattling noise on the front axle investigated and resolved.
This rattling noise occurs almost exclusively when driving at low speeds.
and is particularly noticeable with fully locked steering wheels (e.g., when driving over a curb).
Furthermore, I've recently had the impression that every imperfection in the road surface...
'...which is directly transferred to the pedals, and the handling feels somewhat unstable in corners.'
The shock absorbers seem to be okay so far.
Do you have any ideas about what else still needs to be exchanged?
Sure, no problem.
(Or: You're welcome.)
JL
Translated on 09-08-2026, 7:09.
Arne
Post09-05-2005, 8:16    Subject: Steering Noise: Causes & How to Fix It Quote
It might be a good idea to replace the dome bearings – it's not a big or expensive job...
arne
Translated on 09-08-2026, 7:10.
cetano
Avatar-cetano
Post16-05-2005, 16:27    Subject: Steering Noise: Causes & How to Fix It Quote
Check the two rubber bushings on the stabilizer bar. The older bushings were installed with clamps without a locking mechanism and are a weak point. The newer ones (replacement parts) have a locking mechanism and hold better. Inspect them while the vehicle is lifted, with the wheels loaded, and the stabilizer bar in its "working" position.
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 09-08-2026, 7:11.
Back to top Profile PM Email
andre
Post17-05-2005, 12:23    Subject: Steering Noise: Causes & How to Fix It Quote
If none of that was the problem, and you're still unsure what's causing it, check the outer tie rod ends.
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Steering Noise: Causes & How to Fix It Transmission, Chassis, Body & Interior
No new posts Car Suspension Noise When Starting Transmission, Chassis, Body & Interior
No new posts VA Noise When Braking in Curves Transmission, Chassis, Body & Interior
No new posts VA Polter Ibiza 6L: Hard Cupra Suspension? Transmission, Chassis, Body & Interior
