VW Sport Suspension
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Ernst S.
Post30-05-2002, 17:02    Subject: VW Sport Suspension Quote
The Passat offers an optional sport suspension and an off-road suspension as additional equipment.
I want to drive in a sporty way, but I actually don't want the 2cm lowering that comes with a sport suspension (as I occasionally drive on gravel roads).
Question: Does the off-road suspension system make the car feel sportier when driving on a normal road? It has a stiffer suspension setup, similar to a sports suspension, and now it also has reduced ground clearance.
Does anyone have experience with the different suspension systems? Thank you.
eike
Post30-05-2002, 20:05    Subject: Re: VW Sport Suspension Quote
I'm constantly on the road with a trunk full of tools. It weighed so much that the car noticeably sagged, and the shocks were worn out after 100,000 kilometers.
Then, an off-road suspension system was installed in the rear. It features reinforced shock absorbers and longer springs. After that, the car looked slightly raised when empty, but when loaded, it looked the same as it did when empty.
If you want a stiffer suspension without sacrificing ground clearance, you should consider adjustable gas-pressure shock absorbers (like Koni or similar) and low-profile tires on alloy wheels (which reduce unsprung mass).
Eike.
No new posts Original VW Sportfahrwerk Transmission, Chassis, Body & Interior
No new posts Feder HA gebrochen A4 B5 Quattro, Sportfahrwerk; Ersatz? Transmission, Chassis, Body & Interior
