A3 (8P): Replace Turn Signal Bulbs
hueso
Post15-10-2003, 9:30    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
I was just about to replace the turn signal bulbs in my new A3 (8p), but I'm not really making any progress. I found the three Torx screws. I completely unscrewed the one in the middle, and loosened the ones on the sides. Even though everything was loose, I couldn't get the headlight out. Can anyone help me? Do you even need to remove the entire headlight?
Translated on 29-09-2026, 7:20.
Michael II
Post15-10-2003, 10:19    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
What kind of engine is it?
(This might sound strange, but the procedure may vary depending on the engine.)
Tschüss
Michael II
Translated on 29-09-2026, 7:21.
hueso
Post15-10-2003, 10:38    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
It is a 1.9 TDI icon_biggrin.gif.
Michael II
Post15-10-2003, 11:00    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
Right headlight:
Pull the fuel filter, with its attached hoses, upwards out of the bracket.
Release the retaining tongue on the plastic cover, then remove the housing cover for the low beam from the headlight housing.
Left headlight:
Tschüss
Michael II
Translated on 29-09-2026, 7:22.
hueso
Post15-10-2003, 11:08    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
Thank you!
I'll try it tonight! I'm not entirely sure what you mean by 'hold the plastic cover with your tongue,' but I'll figure it out. What's surprising is that no screws (except for the diesel filter) need to be loosened.
Best regards, Hüso.
Translated on 29-09-2026, 7:23.
Michael II
Post15-10-2003, 11:44    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
My mistake. I was preoccupied with the headlights.
Here are the turn signals (front).
Remove the front wheel.
Remove the front radiator shroud.
Rotate the bezel counterclockwise and pull it out of the case.
Rear lights:
Remove the cover plug from the trunk lining.
Turn the witch's hat upside down.
Swing the rear light slightly outwards from the inside.
Remove the headlight by gently rotating it outwards and pulling it free from the clip nuts.
Tschüss
Michael II
Translated on 29-09-2026, 7:24.
Gremlin
Post15-10-2003, 13:05    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
Is this a joke?
The Peugeot 106 still has a 'maintenance access panel,' which is something.
CU Gremlin.
Translated on 29-09-2026, 7:25.
hueso
Post15-10-2003, 13:08    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
Is it possible to remove the fender liner without any issues? I once read in a forum that the shock absorbers need to be removed for this. Is that true?
Translated on 29-09-2026, 7:26.
Michael II
Post15-10-2003, 13:43    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
@GremlinViewing profile: Gremlin: Unfortunately, this is no joke.
@hueso: You can leave the shock absorbers in.
Tschüss
Michael II
hueso
Post15-10-2003, 20:27    Subject: A3 (8P): Replace Turn Signal Bulbs Quote
@Michael II: Thank you very much!!! It worked exactly as you described. It's not so bad if you take your time and approach it calmly.
I actually installed Osram Diadem bulbs. I find the effect to be rather underwhelming. The reflections inside the headlight sometimes still make it appear orange. Maybe Philips SilverVision bulbs would be a better choice for the A3?
Translated on 29-09-2026, 7:27.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts A3 Creaking Noise: Glove Compartment Issue (8P) Transmission, Chassis, Body & Interior
No new posts Timing Belt Replacement VW TDI 4-Valve Diesel Engine Technology
No new posts Vag-Com, alter Orginaladapter: Passt der auch beim neuen A3 Diesel Engine Technology
No new posts Should you prime a new fuel filter after replacement on a... Diesel Engine Technology
