19-09-2003, 15:39 Subject: RWG-Position at AFN? |
Hello, especially to the AFN drivers,
Unfortunately, Michael's list of engine data does not contain any RWG impact values for the AFN.
Since I started experimenting with my RWG before I had the VAGCOM available to document the RWG voltages  , I would be interested in the original values of other AFN components.
They are relatively easy to determine (even with the engine running and the ignition on): simply access block 19 using VAGCOM.
However, it is possible that the values are not displayed when the engine or pump is hot (as is the case with my tractor), but they should always be displayed when the engine is cold.
If we can get as many responses as possible, we might also be able to see how differently the individual pumps are set up from the factory (if we ignore the deviations in the measuring circuits in each motor computer) . . . Gruß Ulf
Profile PM Garage |
Albrecht Profi-Schrauber
Joined: 05/12/2002 Posts: 284 Karma: +10 / -0 Location: DD
19-09-2003, 19:56 Subject: RWG-Position at AFN? |
Hello Ulf,
I'm doing it this weekend!
Unfortunately, I couldn't use my car today
Best regards
Albrecht 01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
24-09-2003, 18:41 Subject: RWG-Position at AFN? |
Hello Ulf,
Sorry, I just found out about measuring the voltage.
my values are 0.8 V and 4.16 V
Best regards
24-09-2003, 19:01 Subject: RWG-Position at AFN? |
Albrecht wrote: | | The values for me are 0.8 V and 4.16 V |
Hi Albrecht,
thank you for your numerous responses
. . . I was actually hoping to receive multiple values for comparison purposes, but even a single answer is helpful (for my tractor). Gruß Ulf
Profile PM Garage |
Arne Guest
25-09-2003, 10:39 Subject: RWG-Position at AFN? |
Hi Ulf,
I will try to finish it tonight.
arne
Arne Guest
25-09-2003, 19:42 Subject: RWG-Position at AFN? |
Okay,
0,72 Volt and 4,5 Volt
arne
25-09-2003, 20:15 Subject: RWG-Position at AFN? |
Arne wrote: | | So, 0.72 Volt and 4.5 Volt |
Thank you
The difference between the maximum values is also interesting.
If I understand correctly, Albrecht's pump should produce more, especially at higher speeds, when operating at full load, compared to yours:
For example, if the feedback signal for 4.1 volts should be set, Albprecht's pump would already be almost fully open, but yours would still be about 10% from the full open position...
The values of other AFN models would also be of interest, of course! Gruß Ulf
Profile PM Garage |
Arne Guest
26-09-2003, 9:12 Subject: RWG-Position at AFN? |
I still have 2 more AFN's running in my network. I'll try to be there soon, and I'll also connect my laptop.
Having a chip on it probably won't make a difference.
arne
