Hello everyone!
To my knowledge, the starting quantity can be adjusted using VAG-COM. I wanted to try this because I occasionally have some problems with the engine starting, both when it's warm and cold. These problems are not severe, and it usually starts on the second attempt. The injectors and glow plugs are also fine. That's why I just wanted to try it this way.
Does anyone know what the correct login is and where I can change the initial amount?
Has anyone else experienced similar problems with starting the engine, or has anyone tried using a different amount of fuel?
Thank you for your information!
DENNIS
