Nail Polish: PD vs. VP - Which is Better?
WarLord
Post21-09-2003, 13:12    Subject: Nail Polish: PD vs. VP - Which is Better? Quote
'Something I've noticed recently: Last Saturday, we picked up two Touran vehicles with 100 HP PD engines. These engines are making a knocking sound. I've also noticed this knocking on several other new cars. Our 1Z with a VEP (Variable Valve Timing) doesn't do this. Could the VEP be preventing pilot injections, or is the knocking caused by something else? Also, I've noticed that the Tourans are producing a lot of black smoke. I've never seen this on our Passat (maybe it's because I rarely drive behind it *g*). The excessive smoke would suggest that the PD engines aren't performing pilot injections. Does anyone know more about this?'
Best regards, WarLord.
Translated on 26-10-2026, 18:08.
Post21-09-2003, 14:08    Subject: Nail Polish: PD vs. VP - Which is Better? Quote
If you had just read a little bit of the old posts and the quiz, you would have come across a topic about pre-emptive injections in PD (Parkinson's Disease).
- The PD also has a pre-injection feature.
- The PD engine makes more noise (especially when cold) because the fuel injection pressure is higher than in the VP engine.
"This noise problem is common to all high-pressure injection systems. It is only through the pre-injection process that the pressure increase in the cylinder is reduced sufficiently to achieve a reduction in noise."
"With a PD engine, there's a noise that isn't related to the combustion process, but it can be mistaken for it (as it's sometimes louder than the actual combustion sound). The solenoid valves make a hissing (ticking) sound – this noise is not present during idling. This particular sound is a clear indicator of a PD engine."
If the Piezo PD elements are from Siemens VDO, then that noise will also disappear.
Translated on 26-10-2026, 18:10.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Additional coolant heater for the TDI Technical Articles
No new posts VAG-COM does not recognize the control unit for the G40 On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Cold start problem with the 1Z engine not solved *cry* Diesel Engine Technology
No new posts Polo 6R: Sensor Data Not Available On-Board Diagnostics (OBD)
No new posts Lock System Not Blinking? Troubleshooting Guide. Diesel Engine Technology
