Thread Repair: Helicoil vs. Time Sert
Reiner_mit_ei
Post26-08-2003, 7:07    Subject: Thread Repair: Helicoil vs. Time Sert Quote
I would like to buy a thread repair kit because the threads often fail on weekends, and it's always difficult to borrow something then icon_sad.gif.
Okay, here's the translation:
'Now my question: Which would you recommend, Helicoil or Time Sert from Würth? Has anyone here worked with both, so that they can offer a comparison?'
In terms of price, Würth is considerably more expensive, but that doesn't necessarily mean it's better.
Thank you.
Pure.
Translated on 01-09-2026, 20:25.
haehnlein
Post26-08-2003, 20:10    Subject: Thread Repair: Helicoil vs. Time Sert Quote
Hi Reiner,
I had Helicoil threads installed into my defective glow plug threads (steel into aluminum) -> they work perfectly (and only require 15 Nm of torque). It depends on what kind of stresses they are exposed to icon_question.gif.
____________
Kein Auto mehr!
Translated on 01-09-2026, 20:26.
joergs
Post21-09-2003, 16:39    Subject: Thread Repair: Helicoil vs. Time Sert Quote
I purchased V-Coil inserts from Völkel in Remscheid (www.voelkel.com) because Helicoil sets were unavailable. These inserts use springs wound to match the thread pitch. I've used them to 'repair' two spark plug threads and one thread for the timing chain tensioner. It was all straightforward, and they hold up well to tightening torque! The tool set for each thread type costs approximately 30 euros.
Translated on 01-09-2026, 20:27.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Flange Thread Repair G3 AFN Diesel Engine Technology
No new posts Frage zur Helicoil-Gewindeeinsatz-Montage Diesel Engine Technology
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
