VP37: Common Issues & Problems in Old Age
Post19-09-2003, 15:40    Subject: VP37: Common Issues & Problems in Old Age Quote
Hello everyone,
Several cases of VP 37 engines exhibiting jerky operation have already been documented here, which were only resolved by replacing the pump – obviously due to wear and tear on the old pump.
Does anyone actually know which parts of the VP 37 tend to fail with high mileage?
Does the MSW wave trigger a response, causing the MSW-RWG-engine control unit feedback loop to oscillate?
Or does the wave become difficult to move due to deposits, causing the system to overshoot when "forcibly" adjusted?
Or does the eccentric cause the control slide to move, such that the slide flutters back and forth uncontrollably during operation?
Or or or...?
Translated on 19-09-2026, 11:41.
Gremlin
Post19-09-2003, 19:14    Subject: VP37: Common Issues & Problems in Old Age Quote
I think it's more likely a combination of all the worn-out parts.
On one hand, you have the flap that opens the steering edge. This flap is almost certainly subject to wear along its edge, even if the design attempts to mitigate this.
'In this case, deposits will certainly form between the distributor piston and the sleeve, as well as inside the distributor housing. Contaminants have a particularly strong effect here.'
Next, the pressure relief valves.
On the low-pressure side, the injection nozzle and the feed pump are most affected. Of course, the eccentric could also fail.
Personally, I believe wear is more likely to occur in the high-pressure components, specifically the distributor piston and the control sleeve.
Starting on the 29th, I can start digging around again icon_wink.gif.
CU Gremlin.
Translated on 19-09-2026, 11:43.
No new posts MSA15 Control Unit: How to Identify a 1Z Model? On-Board Diagnostics (OBD)
No new posts Turbo Failure: Common Causes in Tuned Engines Diesel Engine Technology
No new posts Alter fabrikneuer Reifen Transmission, Chassis, Body & Interior
No new posts Alter Audi Benziner mit Diesel Charakteristik? Diesel Engine Technology
