TDIs dry driving?
Post02-10-2003, 7:25    Subject: TDIs dry driving? Quote
I have previously driven my G2 Diesel (JP) dry several times and then re-started it.
I also had my 1Z (which has a VP37, right?)
Now I just read that a TDI with VP44 engine should never be exposed to dry conditions...
http://www.avlditest.com/wDownloads/news/press02.pdf
Does this apply to the VP44 and also to the VP37?
Thank you.
Uli S.
Post02-10-2003, 8:21    Subject: TDIs dry driving? Quote
take a look over there:
http://www.fatty-fuels.de/messages/28911.html
Axial piston pumps seem to handle this better, but at least, the pumps are officially refilled with organ music after being idle.
Best regards, Uli
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Post02-10-2003, 8:23    Subject: TDIs dry driving? Quote
... or even here in the forum:
/viewtopic.php?t=2148
Diesel.gustav has already written about drying out the VP44.
Post02-10-2003, 10:20    Subject: TDIs dry driving? Quote
Thank you.
I was only searching for "dry driving" and found nothing.
So, dürfen wir also die 4-Zylinder VP TDIs ruhig trocken fahren?
PDs also?
Post02-10-2003, 10:46    Subject: TDIs dry driving? Quote
... and I wouldn't stand for that either. At least, a VP37 is not quite as sensitive as a VP44.
These pumps are all lubricated with diesel; if the lubricant is missing, it becomes critical.
PDs also?
Gremlin
Post02-10-2003, 12:30    Subject: TDIs dry driving? Quote
so, the VP37 should not be dried out.
The VP44 should not be allowed to dry out. IIRC, they also detect air in the low-pressure circuit and then simply flag it as an error.
PDs also don't really tolerate air either, but there, due to the pre-pumping pump, restarting is a bit easier. Since the product is first fed into the rail (where it is also vented via the over-flow throttle), the whole process is relatively straightforward.
Generally applicable. Avoid driving on dry roads under all circumstances!
When changing pumps or filters, ALWAYS fill the component. When changing filters, people often say 'oh, the pump will suck it in anyway.' However, this is not true, and the battery will be drained and the pump will fail.
See you, Gremlin
Dan.jel
Post02-10-2003, 14:54    Subject: TDIs dry driving? Quote
I had already emptied the first pump nozzle... (AJM)
Nothing happened, I just had to play the organ for 1.5 minutes... icon_rolleyes.gif
No new posts Used car inspection tips for TDIs Technical Articles
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts [Poll] Turboladerlebensdauer bei TDIs Diesel Engine Technology
No new posts TDI Overview: Features & Benefits Diesel Engine Technology
No new posts EGR Valve for 2.0L TDI Engines Diesel Engine Technology
No new posts Common 3.0L V6 TDI Engine Problems & Weaknesses Diesel Engine Technology
