Doku Audi 8P, Control Lamp Test (Solution)
Michael II
Post27-10-2003, 20:13    Subject: Doku Audi 8P, Control Lamp Test Quote
"Control Lamp Test Combination Instrument" error code entry
Cause:
Due to a software error, the error "01298 - Control lamp test combination instrument recorded in the fuse box unit's fault memory.
Solution:
If the error can be cleared using the "Clear Diagnostic Memory" function, it can be disregarded. He will then be re-entered under certain conditions, but this does not restrict its functionality and is not visible to the customer.
However, if the error is static, it cannot be deleted.
Tschüss
Michael II
Ratings - Doku Audi 8P, Control Lamp Test
No new posts Doku Audi, Fehler am Elektrolüfter Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi, up to 2:00 AM, insufficient heating power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 documentation, fault in the secondary air system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
No new posts Audi A8 4.0 TDI Diesel Engine Technology
