Transmission noise
donalexo
Post30-09-2003, 12:28    Subject: Transmission noise Quote
Hello fellow mechanics!
"For some time now, I've been noticing increasingly loud noises coming from the transmission in my A3. The noises are particularly noticeable at very low speeds (between approximately 40 and 70 km/h), regardless of the gear selected. This, in my opinion, suggests a problem with the drive shaft (differential) or the bearings of the main transmission shaft. The difference between the noise produced during acceleration and deceleration is minimal. The noise is best detected when the car is rolling (with the clutch disengaged), as the engine noise is less dominant then."
I noticed the following links in the knowledge base:
/viewtopic.php?t=3970
/viewtopic.php?t=3656
In my CZL gearbox, there is definitely no hollow shaft installed on the left side.
Could the thing about the transfer case actually be true (MJ 1997), or what?
Okay, the current mileage is 140,000 km.
The gearbox appears to be sealed, and there is no visible leakage from the shaft seals or flange seals.
Who has ideas and suggestions?
Alex.
Touran 1.9 TDI, EZ 09/2004
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post30-09-2003, 16:35    Subject: Transmission noise Quote
Hmmm...
Unfortunately, I don't have an answer to your problem either.
I also experience a grinding noise at speeds of approximately 20-60 km/h.
Since it's an A3, it probably wouldn't be a bad idea if...
Please post this in the A3 forum.
Sure, here's the translation:
"Best regards."
Julian
Post30-09-2003, 18:31    Subject: Transmission noise Quote
Another question: Have you considered the wheel bearings? 140,000 miles doesn't necessarily indicate transmission damage, as long as there are no external leaks. Transmission fluid level checked; a change might help, if it's not the wheel bearings.
A differential could also be an option...
donalexo
Post30-09-2003, 21:04    Subject: Transmission noise Quote
Hello everyone,
Well, it's definitely not the wheel bearings, because I had a wheel bearing failure on the front axle just about 5,000 km ago, which of course was fixed. And I can only emphasize that the background noise was completely different.
Regarding the differential: Is it possible to replace the differential relatively easily, without having to disassemble the rest of the transmission, or is the design more complicated and unfriendly?
@JulianViewing profile: Julian:
I initially thought about changing the transmission fluid, as that would likely be the cheapest solution if it makes a difference.
"Does anyone have experience with gearbox repair work?"
Thank you in advance.
Alex.
garth.brooks
Post30-09-2003, 23:21    Subject: wheel bearing Quote
Regarding wheel bearings, I can add that they tend to become noticeably louder when cornering, whereas the transmission is less likely to make that kind of noise (unless there's a differential problem).
(disconnected, or 'N' - then it's clearly audible.)
My mileage is already at 165,000 kilometers, but they should still last a while. (Not everything that's said is necessarily true.)
Julian
Post01-10-2003, 8:58    Subject: Transmission noise Quote
As long as no gears pop out or someone tries to engage a gear, I would leave it at checking the transmission fluid level.
D.
Post01-10-2003, 19:49    Subject: Transmission noise Quote
What is the sound of the transmission when the car is stationary/idling, with and without the clutch pedal depressed?
christians
Post01-10-2003, 20:57    Subject: Transmission noise Quote
My Audi 100 also has a similar "constant" noise, but at speeds of 70-100 km/h, which is probably due to the additional cylinder.
The transmissions are, of course, completely different from those in the A3.
For me, an oil change didn't make any difference. There weren't a particularly large amount of wood chips in the oil.
Gruß Christian
No new posts Document A3 8P1, BMJ, GMU - Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L: Transmission Noise Diagnosis Diesel Engine Technology
