VW T4 2.5 TDI shuts off / won't start
wacken
Post28-09-2003, 16:35    Subject: VW T4 2.5 TDI shuts off / won't start Quote
Hello, my father is having a problem with his T4, and I'm hoping someone here can help.
Is this a 2.5-liter TDI engine with 102 horsepower, engine code ACV, manufactured in June 1996?
Sometimes the car doesn't start, regardless of whether the engine is warm or cold. Then, the yellow preheating light 'flickers' dimly, but the engine turns over. If you turn the ignition on and off several times until the preheating indicator lights up properly, it will then start.
During the ride, it sometimes stalls, and the red battery warning light comes on. If the clutch isn't disengaged, it restarts after one or two seconds.
We already replaced the 'absteller' (solenoid valve), but unfortunately, it didn't work.
Who can help?
Michael II
Post28-09-2003, 18:24    Subject: VW T4 2.5 TDI shuts off / won't start Quote
Have you checked that already?
Cause:
The engine will not start if the contact pressure between terminals 15 and 50 in the ignition switch is too low, or if the connector is not properly seated.
Another possible candidate is the power supply relay.
What does the error memory say?
Tschüss
Michael II
wacken
Post28-09-2003, 19:16    Subject: VW T4 2.5 TDI shuts off / won't start Quote
Okay, so the error memory is clear.
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
No new posts Passat, manufactured in 1994, engine 1Z stalls and won't ... On-Board Diagnostics (OBD)
No new posts 2.0 TDI CBBB: Engine Stalling & No Start? Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
