TDI Engine: Won't Start After Head Repair
dcjf
Post01-11-2003, 13:15    Subject: TDI Engine: Won't Start After Head Repair Quote
Help!
'At 25,000 km, the timing belt was replaced by the dealer at 240,000 km, but it still failed. Fortunately, only three valves were bent and two hydraulic lifters were broken. After reassembly (with correct timing), the engine doesn't start, and it doesn't even spark when jump-started. However, when jump-starting and giving it gas, white smoke comes out from the back.'
Does anyone have any advice?
Translated on 02-11-2026, 17:28.
Thomas
Post01-11-2003, 16:38    Subject: TDI Engine: Won't Start After Head Repair Quote
As far as I can tell, white smoke always indicates the presence of (cooling) water in the combustion chamber.
Are you sure that the head was undamaged after the accident, or that nothing else was damaged?
Greetings.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 02-11-2026, 17:29.
christians
Post01-11-2003, 20:58    Subject: TDI Engine: Won't Start After Head Repair Quote
Thomas wrote:
As far as I can tell, white smoke usually indicates coolant in the combustion chamber.
White smoke can indicate water, but it doesn't necessarily have to. In this case, the engine isn't running, so I'd like to rule that out as a possibility.
It's likely unburned diesel fuel that's being injected, which is also easily recognizable by the smell.
Unless there's an extreme case where there's no compression in all cylinders, the injection timing is likely incorrect.
Okay, let's measure everything again!
Gruß Christian
Translated on 02-11-2026, 17:30.
dcjf
Post09-11-2003, 11:37    Subject: TDI Engine: Won't Start After Head Repair Quote
Well, the imprinted markings were probably incorrect. That's also why there are obviously later-added color markings on the pump.
It's working again!
Translated on 02-11-2026, 17:31.
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKE won't start after pump replacement Diesel Engine Technology
No new posts Golf IV ARL: No Start After DPF Delete? Diesel Engine Technology
No new posts Engine won't start - after PDE replacement Diesel Engine Technology
No new posts BMW 320d E46: Won't Start After Head Gasket Replacement Diesel Engine Technology
