Would it be possible to transfer the GRA lever from the new Passat with...?
Go to page: 1, 2  Next
WarLord
Post05-10-2003, 16:30    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Is it possible to install speed increase and decrease modules (I'm not sure how to describe it) in a Passat 35i 3A5 with a 1Z engine? I suspect it might not be possible, but if it is, it would be great. Okay, here's the translation:
'Then I have another question about the other GRA (meaning the appropriate one): If you tap the clutch or the brake, does the GRA go back into standby mode, or does it immediately reactivate and start accelerating again?'
Best regards, WarLord.
Translated on 05-07-2026, 0:18.
Post05-10-2003, 17:37    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
If your engine control unit (ECU) supports this function, it shouldn't be a problem. My 1Z only knew how to accelerate; the other lever wouldn't have made any difference.
Translated on 05-07-2026, 0:19.
WarLord
Post05-10-2003, 18:00    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Well, it's just a small car, and I don't think it's capable of doing that. What about the clutch and the brakes?
Translated on 05-07-2026, 0:20.
Post05-10-2003, 18:02    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
WarLord wrote:
Well, it's just a 1Z, and I don't think he's mastered it.
...I don't think so either.
Problem-free - is available (assuming you mean the pedal position recognition).
WarLord
Post05-10-2003, 18:13    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
No, that's not what I mean. I mean, does the GRA then return to standby mode when you release the clutch or brake pedal, or does it accelerate back to the set speed?
Translated on 05-07-2026, 0:21.
Post05-10-2003, 19:39    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Yes, by pressing the "Reset" button. That's definitely possible.
WarLord
Post05-10-2003, 19:47    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Yes, I understand that already. I'm interested to know if the car automatically accelerates back to the set speed immediately after releasing the clutch or the brake, or if you have to press the RES button (essentially like the new GRA system).
Translated on 05-07-2026, 0:22.
Avatar-Jan6K
Post05-10-2003, 19:49    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
I think Warlord just wanted to know what normally happens when you brake.
Brake or clutch -> Readiness.
Res(et) -> accelerate again.
You can therefore brake or clutch without any risk... I use it as an "on/off switch" and leave the GRA (presumably a system or feature) constantly on, activating it only via set or reset.
Jan.
1Z5 CFHF / AHB H4D
Translated on 05-07-2026, 0:23.
WarLord
Post05-10-2003, 19:51    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
You have a newer car, right? Do you have the GRA lever with one button or the one with two buttons? I'm especially interested in how the 1Z version performs. You understood what I meant.
Translated on 05-07-2026, 0:24.
Avatar-Jan6K
Post05-10-2003, 20:18    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Yep, using an ASV machine.
There's a slider for on/off, but you can slide it past the "ON" position to "RES" (it doesn't click into place there). In addition, there is also a button for "SET".
In standby mode (ON), tapping the SET button initiates the programming of the current speed, but interestingly, this only works if you are applying at least a little bit of throttle. RES restores the previously selected speed.
In active mode, tapping SET results in a change of approximately -1 km/h, while tapping RES results in a change of icon_smile_thumb_up.gif km/h. Holding the button down will decelerate or accelerate.
In track 1, only one of the two directions should be active - see the other posts.
Jan.
1Z5 CFHF / AHB H4D
Translated on 05-07-2026, 0:25.
Post06-10-2003, 6:12    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Just a small note regarding Jan's description: there are two different types of GRA levers in the G4.
[img][/img]
One works as Jan describes, while the other (since 05/01) has a +/- toggle switch on the side.http://www.michaelneuhaus.de/golf/pic/g4_gra.jpg{MARKER}
Translated on 05-07-2026, 0:26.
Rudi
Post06-10-2003, 7:03    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Hi warlord,
The 1Z behaves exactly as Jan described.
The speed reduction input is missing on the transmission.
Best regards, Rudi.
Translated on 05-07-2026, 0:27.
x world one
Post06-10-2003, 7:26    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Do you mean on the steering wheel? Our G4 has a GRA lever that can only be turned on. All the other buttons are located on the steering wheel.
Spritmonitor
Translated on 05-07-2026, 0:28.
Post06-10-2003, 7:27    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
Rudi wrote:
The input for speed reduction is missing on the transmission.
icon_question.gif icon_question.gif icon_question.gif My 1Z had the entrance, but icon_wink.gif
... The "-" function is implemented via the "RES" function, and the reset signal is wired throughout the system. However, the STG software cannot translate the longer press of the "RES" button into the "Slower" command. I think that's what Rudi meant.
By the way, the G4 has the "+" function on the "RES" button and the "-" function on the "SET" button, while the G3 has the opposite configuration ("SET" = "+").
Translated on 05-07-2026, 0:29.
Post06-10-2003, 7:30    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
x world one wrote:
Do you mean on the steering wheel? Our G4 has a GRA lever that can only be turned on. All other buttons are located on the steering wheel.
"Yes, they do exist. However, that's part of the standard equipment or comfort features." Normally, the turn signal switch is located where the GRA (Gaspedalrückholautomatik - accelerator return automatic) controls are.
Translated on 05-07-2026, 0:31.
Rudi
Post06-10-2003, 9:18    Subject: Would it be possible to transfer the GRA lever from the new Passat with...? Quote
... The '-' function is implemented via the 'RES' function, and the reset signal is wired throughout the system. However, the STG software cannot translate the longer press of the 'RES' button into the 'Slower' command. I think that's what Rudi meant.
By the way, the G4 has the '+' function on the 'RES' key and the '-' function on the 'SET' key, while on the G3 it's exactly the opposite ('SET'='+').
Hi Bertil,
You're right! Typed faster than expected again icon_redface.gif.
By the way, RES does not stand for 'reset,' but for 'resume,' meaning 'continue.'
Best regards, Rudi.
Translated on 05-07-2026, 0:32.
No new posts Lupo 6X1 MJ 2002: Broken Flap Lock Lever Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B ABS FS reading not possible! On-Board Diagnostics (OBD)
No new posts GRA Lever: €86 - Is It Worth It? Diesel Engine Technology
No new posts 02J Gearbox Shift Lever: What is it for? Diesel Engine Technology
No new posts Cruise control in A3 8P using a Golf 5 lever Diesel Engine Technology
