Injector Replacement: Audi A3 1.9 TDI Tips
joe
Post09-10-2003, 9:43    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
The needle lift sensor on my son's Audi 80 TDI 1Z is broken. We found a used one that supposedly works. What should be considered when replacing it? Is a new gasket recommended, or is it mandatory? What torque should be used for the screw?
Thank you for the answers!
Translated on 18-08-2026, 21:12.
Weini
Post09-10-2003, 9:56    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
The tightening torque is 20 Nm. The copper gasket must be replaced at the same time (it only costs a few cents).
It's best to replace the hoses from the return line of the nozzles at the same time (they are often brittle and tend to leak after being disconnected and reconnected).
It should all be done in about 20 minutes - have fun!
Weini
Translated on 18-08-2026, 21:13.
Arne
Post09-10-2003, 10:20    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
I think Ulf might have had something in his nozzles that caused them to be slightly misaligned when tightened, which made the engine sound a bit rougher. Take another look at Ulf's article about it – I think it contains all the information about replacing the nozzles.
arne
Translated on 18-08-2026, 21:14.
Post09-10-2003, 16:33    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
Arne wrote:
I think Ulf might have had something in his nozzles that, when tightened, caused them to be misaligned, which made the engine sound a bit rougher. Take another look at Ulf's article about it - I think it also contains everything else about changing the nozzles.
The story about the altered engine noise is presented in its own separate short article.
Otherwise, please refer to the articles on jet replacement tuning, as Arne already mentioned.
Translated on 18-08-2026, 21:15.
Gremlin
Post09-10-2003, 20:52    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
By the way, that beautiful metallic clicking sound (like a hammer on an anvil) from the NBF nozzle disappeared for me after about 300 km...
It seems like they're giving these things away at every concert.
CU Gremlin.
Translated on 18-08-2026, 21:16.
joe
Post10-10-2003, 8:16    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
Thank you for the tips, I'll get started now.
Translated on 18-08-2026, 21:17.
haehnlein
Post11-10-2003, 23:21    Subject: Injector Replacement: Audi A3 1.9 TDI Tips Quote
and above all, pay attention to meticulous cleanliness icon_exclaim.gif.
____________
Kein Auto mehr!
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts Fuel Injectors AFN: Replacement Guide Diesel Engine Technology
No new posts Fuel Injector Replacement: PD Wear & Issues On-Board Diagnostics (OBD)
No new posts Replace Fuel Injectors: DIY Guide & Tips Diesel Engine Technology
No new posts Replacing the AFN control unit in an Audi A4 On-Board Diagnostics (OBD)
