Is the wireless doorbell broken?
SST
Post27-05-2002, 11:50    Subject: Is the wireless doorbell broken? Quote
'Recently, my FunK home automation system has stopped working, despite...'
Battery replacement!
Do you have any experience with that?
Passat AFN.
Translated on 10-07-2026, 5:15.
Andy
Post27-05-2002, 18:43    Subject: Relearning...? Quote
After replacing the battery, some remote controls need to be reprogrammed. This is also the case with my Votex remote control in my Volkswagen Golf III.
Okay, let me get the instructions out and take a look...
Translated on 10-07-2026, 5:16.
SST
Post31-05-2002, 10:47    Subject: Is the wireless doorbell broken? Quote
Unfortunately, it didn't work either; it only worked once.
when I was very close to the receiver.
Post31-05-2002, 10:50    Subject: Is the wireless doorbell broken? Quote
Have you ever thought that the new batteries might be faulty?
It happened to me personally that I acquired new but very well-aged specimens that I had to dispose of immediately.
Since then, I only buy batteries from stores that seem to have a high turnover rate (so they don't end up sitting on the shelves and going bad).
"Could you measure the voltage? Button cells usually have around 3V, but it should also be printed on the battery itself. You could also try drawing a few milliamps using a resistor bridge to make sure the voltage doesn't drop under load. However, with dead button cells, I've always measured significantly below 3V just by connecting them to a measuring device."
Translated on 10-07-2026, 5:17.
Ernst S.
Post31-05-2002, 12:28    Subject: Goodwill Quote
'My remote central locking system had been working increasingly poorly after 2 years. Replacing the batteries didn't help either. I immediately received a new one from my car dealership free of charge. It seems to be a known problem; they apparently had replacements ready for every Passat (model year 1998).'
Translated on 10-07-2026, 5:19.
SST
Post03-06-2002, 7:54    Subject: Is the wireless doorbell broken? Quote
Sure, thanks.
I suspect there's nothing more they can do for me with goodwill, but my car is from 1997 icon_rolleyes.gif.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alarm System: Troubleshooting Wireless & Door/Window ... On-Board Diagnostics (OBD)
No new posts Remote Central Locking VW Passat Diesel Engine Technology
No new posts Are radio influences on ECUs possible? On-Board Diagnostics (OBD)
No new posts Remotely control the window lifters in a VW Golf4 Variant... On-Board Diagnostics (OBD)
