Injection pump, identical?
Lucas
Post03-11-2003, 9:56    Subject: Injection pump, identical? Quote
Good morning!
'In my Audi 80 1Z, the following ESP (Electronic Stability Program) unit is installed: 0 460 404 995. Unfortunately, it has now developed a leak after 366,000 kilometers, so I am looking for a replacement.'
It's the first 1Z with 182 Nm of torque.
'Is a Bosch 0 460 404 998 compatible with my fuel pump? I've noticed that it also has the round multi-pin connector, which, as far as I know, was only used in older 1Z models with potentiometer-based quantity control systems up to around 1994.'
Perhaps someone knows something about this and can confirm or deny it for me.
By the way: Henzo from www.dieselsend no longer creates custom ESPs icon_sad.gif.
Lucas.
Translated on 17-07-2026, 14:01.
Lucas
Post03-11-2003, 14:57    Subject: Injection pump, identical? Quote
I found something else that might be helpful as an addition.
Bosch Part No. / VAG Part No.
until February 1994.
0 460 404 995 / 028 130 109
until August 1992.
0 460 404 998 / 028 130 108 M
So, they're probably not replaceable after all. But what exactly was changed there? - On the nozzles?
Translated on 17-07-2026, 14:03.
michaB4
Post03-11-2003, 15:55    Subject: Injection pump, identical? Quote
Hello Lucas,
until 8/1992.
likely for the 1Z engine variant with indirect injection nozzles without pre-injection (resulting in a more aggressive engine running).
until 2.1994.
0 460 404 995 / 028 130 109 J
presumably for engines with throttle potentiometer sensors, mass airflow sensors using bypass valves, etc., like the ones you and I have.
My repair manual states that these two pumps are not compatible because they each require a different engine control unit (ECU). Unfortunately, I don't have any personal experience with them.
Michael.
Translated on 17-07-2026, 14:05.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Are the AFN and AHU cable harnesses identical? Diesel Engine Technology
No new posts Which PDEs are identical? Diesel Engine Technology
No new posts Are Caddy TDIs with 105 hp and 75 hp identical (except fo... Diesel Engine Technology
No new posts Oil Pan: Same for 85kW/96kW Engines? Diesel Engine Technology
