It's practically impossible with the Beta version...
However, there is a switch for the speaker outputs.
I still have one from my old radio that didn't have a mute function.
As soon as a call came in on the phone, the speaker inputs were disabled, and internally, the signal from the hands-free equipment (HFP) was routed from the 3.5mm jack to the speaker outputs.
Unfortunately, it only supports the front two channels. (However, you can switch to the rear channels depending on your intended use.)
'Meanwhile, I've connected a separate speaker to my hands-free system, and my radio mutes itself through the 'mute' input.'
The solution using the AUX input on the Pioneer would have been too expensive and pointless, as I only rarely make phone calls in the car... (It would always have required manual switching).
That would actually be ideal for voice output from the navigation system!
If available, you'll continue to hear the radio through the rear speakers, while the front speakers briefly tell you where you want to go, after which the radio will resume playing.
If you're interested in the small box, just let me know!
I was thinking of 20 euros including shipping.
Trying and testing is not a problem; we will definitely find an agreement!
