Wastegate valve clicking constantly?
DocSnydor
Post27-05-2002, 13:40    Subject: Wastegate valve clicking constantly? Quote
Sure, here's the translation:
'Just a question:'
In my Passat 35i 1Z, there's a small box in the engine compartment at the front that clicks (and will soon rattle) icon_redface.gif. I unfortunately don't remember the name }, but it's definitely related to the turbocharger pressure.
Is this normal, or should it be replaced? The car seems to be driving normally. What are the consequences if this part is defective?
Sure, no problem.
David.
Translated on 21-09-2026, 11:36.
C.F.
Post27-05-2002, 14:26    Subject: Wastegate valve clicking constantly? Quote
Hi.
das ist völlig normal. Wenn es defekt ist geht das Steuergerät in den Notlauf wegen zu hohem Ladedruck. Kapproximately 25 €.
Best regards, Claus.
Translated on 21-09-2026, 11:37.
Michael II
Post27-05-2002, 14:28    Subject: Wastegate valve clicking constantly? Quote
It's normal for the valve to click or tick. If you hear rattling, I would check to make sure the valve is still securely fastened.
If that doesn't help, I would replace the valve.
Tschüss
Michael II
AMB1980
Post27-05-2002, 15:14    Subject: Wastegate valve clicking constantly? Quote
'In my Golf 3 (engine code AHU), this part always starts making a clicking noise right before it fails. I've already replaced it four times.'
Translated on 21-09-2026, 11:38.
DocSnydor
Post28-05-2002, 8:28    Subject: Wastegate valve clicking constantly? Quote
Thank you for the answers.
Let's see how it develops...
I just noticed it when I recently had the hood open with the engine running, and our company's TDI vehicles don't make that noise.
Es klickt ja nicht ab& zu mal sondern die ganze Zeit... Let's see.
Thank you again for your help.
David.
hakeye
Post28-05-2002, 10:26    Subject: Click Here! Find Out More Now. Quote
Hello TDI enthusiasts!
I had the same clicking sound. Michael II also helped me out before.
'In my car, the engine would intermittently go into limp mode (3000 RPM and a maximum speed of 130 km/h). A vacuum hose was kinked, and there were two error codes stored in the system.'
Boost pressure differential.
and, most recently:
Boost pressure valve N75: Open circuit/Short circuit to ground.
The valve will be replaced tomorrow, and I hope that will solve the problem!
Hawkeye.
Translated on 21-09-2026, 11:40.
hakeye
Post02-06-2002, 16:30    Subject: Quiet, but not a solution! Quote
The magnetic valve N75 has been replaced, but the limp mode persists icon_sad.gif.
It clicks, but noticeably quieter icon_wink.gif.
Well, let's see if the workshop can manage to fix it???
Hawkeye.
Translated on 21-09-2026, 11:41.
No new posts GRA lever installed - return ring clicks Transmission, Chassis, Body & Interior
No new posts Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Diesel Engine Technology
No new posts Battery Draining Fast? Common Causes & Fixes On-Board Diagnostics (OBD)
No new posts Boost Valve: Control & Regulation Diesel Engine Technology
