Upgrade from semi-automatic climate control to Climatronic
MONCHI
Post22-10-2003, 12:44    Subject: Upgrade from semi-automatic climate control to Climatronic Quote
...I have a question.
The Seat Ibiza TDI PD 96KW is available in the Signo version with Climatronic, while the Sport version has a semi-automatic air conditioning system!
Please provide the text you would like me to translate from German to English.
Can this be easily upgraded to a Climatronic system by simply purchasing the electronic module? Do the connectors fit? Is there a wiring harness there?
...this topic has been discussed before, but I still don't understand it.
Thank you in advance for your information!
Marco
Post22-10-2003, 13:01    Subject: Upgrade from semi-automatic climate control to Climatronic Quote
I can only speak about the G4 here, and it's missing not only the control unit, but also all the wiring harnesses and the countless actuators. I think the situation at Seat isn't much better.
FBonNET
Post22-10-2003, 19:08    Subject: Upgrade from semi-automatic climate control to Climatronic Quote
To upgrade the CT manual, the entire blower unit must be replaced, as well as the wiring harness that runs into the engine compartment.
While it's technically possible, it's too expensive without a donor vehicle to source spare parts from.
MONCHI
Post23-10-2003, 8:25    Subject: Upgrade from semi-automatic climate control to Climatronic Quote
...so it makes sense to invest the extra 200 euros for a climate control system (if you need it) when buying a new car.
Monchi.
No new posts Air conditioner smells bad General Tips
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Upgrading an SDI with a turbo? Diesel Engine Technology
No new posts Golf III Climatronic. Fan for temperature sensor. Transmission, Chassis, Body & Interior
No new posts Upgrading your VW T6 Transporter: Useful Modifications &a... Dieselschrauber Bar
No new posts Climatronic Golf IV - Unauthorized adjustment of fan speed Transmission, Chassis, Body & Interior
