VW LT: Black smoke, poor performance
dcjf
Post21-10-2003, 14:24    Subject: VW LT: Black smoke, poor performance Quote
Hello everyone,
A friend has a VW LT van with the following problem. While driving on the highway, it suddenly lost power, initially emitting bluish smoke, then black smoke. Now, it's difficult to start and it's producing black smoke, sometimes also bluish smoke. Additionally, the engine has no power.
Die Steuerzeiten sind i.O. Who has advice?
VW LT, 6-cylinder, non-turbo, non-TDI, 2.5L engine, 180,000 km mileage.
Thank you very much for your answers!
Translated on 19-09-2026, 16:26.
Post21-10-2003, 15:07    Subject: VW LT: Black smoke, poor performance Quote
Valve timing is okay, and is the drive and mounting of the fuel injection pump also in good condition?
Translated on 19-09-2026, 16:27.
Marburger
Post21-10-2003, 16:35    Subject: VW LT: Black smoke, poor performance Quote
Hello.
I've experienced that before too!
So, are there any bubbles visible in the clear diesel line?
Okay, try blowing some air through the filter line towards the tank (gently). Do you hear a loud hissing sound coming from the fuel filler neck?
There should be no pressure build-up in the line (which should have a cross-sectional area of approximately 5 mm).
At that time, the fuel level sensor was clogged with deposits.
Best regards, Marburger.
Translated on 19-09-2026, 16:28.
dcjf
Post23-10-2003, 7:54    Subject: VW LT: Black smoke, poor performance Quote
Timing is correct, no air bubbles in the diesel line, fuel level sensor is working properly.
What else could it be?
Translated on 19-09-2026, 16:29.
dcjf
Post23-10-2003, 7:55    Subject: VW LT: Black smoke, poor performance Quote
Okay, here's the translation:
'Forgot to mention: the fuel injection pump's drive and mounting are also in good condition.'
Post23-10-2003, 17:46    Subject: VW LT: Black smoke, poor performance Quote
The search function is your friend...
/viewtopic.php?t=2002&highlight=black smoke
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.5 TDI (AKN): Black Smoke, Power Loss - Help! Diesel Engine Technology
This topic is locked, you cannot edit or reply. Power Loss & Black Smoke: Warm Engine Problems Diesel Engine Technology
No new posts A6 C4 2.5L AEL: Poor Performance & Smoke On-Board Diagnostics (OBD)
No new posts A5 2.7 TDI - Poor performance/acceleration, possible caus... Diesel Engine Technology
