after thermostat change, slower speed and blinking
misterx
Post17-10-2003, 9:35    Subject: after thermostat change, slower speed and blinking Quote
the indicator lamp
Hi!
I had the thermostat replaced last Monday. The temperature seems to be okay again, and the turbo (slightly) engages more, and the car is overall a bit more responsive (not much). However, last Tuesday, the pre-glow lamp started flashing (only on Tuesday). I immediately made an appointment at VAG and will have the fault memory read tomorrow (I don't have the adapter yet), but I would like to know if you might be able to recognize any connections. The pre-glow lamp flashed on the Autobahn in traffic on Tuesday, and then never again. Although, overall, the described improvement has occurred since the thermostat replacement, several attempts to heat up on the A555 (no limit) failed. Before the thermostat change, I was able to achieve approximately 190 km/h on a straight road, and around 205 km/h downhill with a headwind, according to the speedometer. After the change, I can only manage around 180 km/h on a straight road, and just slightly above that. Car is a Golf III with 1.6 engine, genuine, and with approximately 105,000 km on the odometer.
Could someone perhaps come up with a rhyme for that?
Thank you in advance,
Mr. X
Marco
Post17-10-2003, 9:57    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]Moin,
welches Thermostat wurde denn gewechselt? Und warum wurde es gewechselt?
misterx
Post17-10-2003, 10:05    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]hi!
auf die gefahr hin für dumm gehalten zu werden, ich habe keine ahnung welcher thermostat gewechselt wurde! ich habe hier im forum einen thread gelesen, der einen leistungseinbruch wegen thermostat schilderte. demnach war die kühlwassertemperatur während der fahrt bei etwa 70°C. Da mein golf auch nur 70 Grad hatte (90 C allenfalls wenn ich im stau stand) habe ich auf verdacht mal von vw das ganze wechseln lassen (war garantiefall, also nicht so teuer). Jetzt erreiche ich zwar die solltemperatur, aber mit beschriebenen nebeneffekten.
Hilft dir das weiter?
Gruß,
MisterX
christians
Post17-10-2003, 12:53    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]
Da wird die Werkstatt wohl beim Einbau des KÜHLWASSERthermostaten einen Kollateralschaden verusrsacht haben...
Gruß Christian
misterx
Post17-10-2003, 13:29    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]inwiefern?
was könnte die ursache sein und hätte das was mit dem leistungsverlust zu tun?
Karma: +784 / -0   Thank you, like it!
Post17-10-2003, 13:50    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]
entweder Zufall oder die Werkstatt hat beim Einbau was anderes verpfuscht.
Grüße, Rainer
misterx
Post18-10-2003, 17:21    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]Hi!
also fehlerspeicher auslesen ergab:
Bremspedalüberwachung unplausibles Signal - sporadisch
da das blinken der vorglühlampe nur 1x autrat, meinte der meister ich sollte das weiter beobachten. der leistungsverlust deutete für ihn auf defektem lmm hin! da über gebrauchtwagengarantie abgedeckt und daher nicht so teuer, werde ich den lmm nächsten samstag tauschen lassen.
gruß,
misterx
Post18-10-2003, 21:43    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]
Hi X,
den Schalter am Bremspedal kann man einstellen. -> Suchfunktion.
Grüße,Rainer
misterx
Post20-10-2003, 12:22    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]Hi!
Ich habe heute mal den Diodentest wg. LMM gemacht! Soweit ich das beurteilen kann nimmt der das Gas besser an, aber schneller als 180 km/h fährt er trotzdem nicht. Muss ich unbedingt die AGR stillegen, wenn ich die Diode benutze?
HeikoL
Post31-10-2003, 19:55    Subject: after thermostat change, slower speed and blinking Translating...
[Translating...]Hi zusammen,
ich habe exakt das gleiche Problem - Temperatursensor für Kühlmittel defekt, seidem vMax ca. 175 km/h, früher min. 185 (Sharan TDI PD 85kw Aut.), Beschleunigung ab 160 zäh.
Meine VW-Werkstatt steht vor einem Rätsel. LMM gewechselt, keine Änderung.
Würde mich freuen, wenn dieser Thread wieder Fahrt aufnimmt!
Heiko.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3: LEDs for alarm system blink as desired. Mood Diesel Engine Technology
No new posts Pace Car blinken rauscodieren Golf VII On-Board Diagnostics (OBD)
No new posts A 150 hp TDI, less... Diesel Engine Technology
No new posts ARL ab 3000 rpm weniger Leistung On-Board Diagnostics (OBD)
