Tie Rod Replacement Passat 35i
Albrecht
Post06-11-2003, 13:35    Subject: Tie Rod Replacement Passat 35i Quote
Today, I took my car to the TÜV appointment, but I didn't get the sticker icon_cry.gif.
Reason: The joints on the inner ends of the tie rods, where they connect to the steering gear, have excessive play!
That means the entire tie rods need to be replaced.
I checked the repair manual, and it says that the entire steering rack needs to be removed, which, in my opinion, is only to provide support for the rack.
Actually, I don't really feel like doing that because of the oil lines, steering linkage, etc.
"Does anyone have experience with whether you can do this while the part is installed? You can turn the steering wheel so that you can reach it from the wheel well, right?"
It's a Passat 35i.
Thank you for the tips.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 16-10-2026, 8:56.
Albrecht
Post15-12-2003, 13:15    Subject: Tie Rod Replacement Passat 35i Quote
"It might be of interest to other 35i drivers: You can also remove the tie rods without completely disassembling the steering rack. This can be done by using the thinnest possible open-end wrench to access the tie rods from between the triangular control arms and the engine mount (with the steering in the appropriate position)."
It's still a bit fiddly, especially with the cuffs, but it's definitely better than a complete overhaul!
Albrecht.
Translated on 16-10-2026, 8:58.
Post15-12-2003, 13:19    Subject: Tie Rod Replacement Passat 35i Quote
Translated on 16-10-2026, 8:59.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Replacing shock absorbers on a Passat 35i **Parts Requir... Transmission, Chassis, Body & Interior
No new posts VW Passat Oil Pan Replacement: Lower Engine Mount Transmission, Chassis, Body & Interior
No new posts Air Filter Replacement VW Passat 35i TDI 1Z Diesel Engine Technology
No new posts Passat 35i: Replace Rear Brake Discs Transmission, Chassis, Body & Interior
