Oil Leak MKB AKF: Oil Level Sensor Problem (Solution)
Michael II
Post06-10-2003, 16:12    Subject: Oil Leak MKB AKF: Oil Level Sensor Problem Quote
Oil leak between the oil pan lower section and the oil level sensor.
Cause:
The crimped joints of the threaded rings in the oil pan lower section, which are used to secure the sensor, are not completely oil-tight in some cases.
Affected vehicle identification numbers:
4D 3 N 000 415
Solution:
No parts exchange required.
The threads in the oil pan and the mounting screws must be cleaned and free of engine oil. The sealant AMV 197 500 must be applied to all three mounting screws before the oil level sensor is reinstalled.
Tschüss
Michael II
Translated on 12-09-2026, 9:07.
Ratings - Oil Leak MKB AKF: Oil Level Sensor Problem
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak Motor Block: AFB & AKN Engine Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI AWX Oil Leak: Causes and Solutions Diesel Engine Technology
No new posts Turbocharger Oil Leak: Causes & Fixes Diesel Engine Technology
No new posts Stop Oil Leaks: Repair & Prevention Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil Leak: AFN/Turbo Exhaust Problems Diesel Engine Technology
