Golf 3: 02A Gearbox Shifting Problems
golf3schrauber
Post05-11-2003, 19:55    Subject: Golf 3: 02A Gearbox Shifting Problems Quote
For some time now, it has been very difficult to engage first gear in my Golf.
You really have to push the gear knob firmly to the left to find the gate for first gear.
Today, I took a closer look at the issue. I thoroughly cleaned the shifting mechanism on the gearbox, and I couldn't find any loose screws.
The cable that controls the up-and-down movement (located on the knob on the left or right) connects to a lever at the gearbox, which is mounted in a bushing.
I find that this socket has a lot of play in it.
You can move the cable a few millimeters before the arm starts to move within the gearbox.
So, when I switch, a portion of the leftward movement in the game's storage is lost.
I'd like to know if you also experience such a significant fluctuation in your circuits at this point. Before I make any adjustments, I'd like to know if this is normal.
However, I wouldn't be surprised if these batteries failed after 300,000 kilometers.
Is the engagement mechanism, located on top of the gearbox, available as a separate replacement part, or does one have to replace the entire gearbox?
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 27-10-2026, 4:54.
LZ
Post05-11-2003, 21:55    Subject: Golf 3: 02A Gearbox Shifting Problems Quote
The cable adjustment can be modified: In the neutral position, open the housing of the upper cable and screw the cable further back in the elongated slot, in the direction of travel. The bushings are made of KST, and the installation is a very delicate process.
best regards, robert
Translated on 27-10-2026, 4:56.
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Manual transmission, Difficult to shift gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Switch problems 3A Passat, 1Z Diesel Engine Technology
No new posts Shifting problems with 6-speed DSG Transmission, Chassis, Body & Interior
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
