Error Code N146: Quantity Setting Issue
jenseden
Post03-06-2002, 14:56    Subject: Error Code N146: Quantity Setting Issue Quote
Hello everyone,
During the inspection of my Passat, the following error code was read:
01268 035
Quantity setting - N146.
The friendly VAG (Volkswagen Group) workshop employee said that it was caused by...
Powerbox (PSI, purchased from ATU and professionally installed) and would not be...
further concerning.
The car doesn't have any major problems, except that it sometimes had issues in winter temperatures around 0 degrees Celsius.
He went into emergency mode at maximum speed, but now that it's warmer, he doesn't do that anymore.
more.
Is it true that the error is caused by the power supply unit, or...?
Should I conduct further research?
Thank you for your responses.
Translated on 21-10-2026, 1:39.
Post03-06-2002, 15:49    Subject: Signal Boxes & Power Supplies Quote
Hi.
"Decent" boxing gloves should ideally not cause any errors or malfunctions.
My suggestion: Disconnect the device, clear the memory, and observe whether the error reappears.
If so, is it due to something else (wow, what logic *lol*)?
If the problems are definitely caused by the device --> return it or reduce its power.
Translated on 21-10-2026, 1:40.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Quantity Setting Error: N146 Upper Limit Reached Diesel Engine Technology
No new posts Fault quantity setting in the fault memory On-Board Diagnostics (OBD)
No new posts Error: Lower limit setting for quantity control in AFN Diesel Engine Technology
No new posts 01268 Quantity setting (upper limit) error, likely found On-Board Diagnostics (OBD)
