WFS Errors: Troubleshooting and Solutions
Schneemann
Avatar-Schneemann
Post05-11-2003, 19:36    Subject: WFS Errors: Troubleshooting and Solutions Quote
Good evening, everyone.
I read out a seemingly pointless error code from the immobilizer today.
00546 Data line fault.
27-00: Implausible signal.
Does anyone have experience with this system and know what it means in plain language?
The car is a 1997 G3 with an AFN engine, and it starts perfectly fine despite this message.
It's not really important since the car is running, but it just bothers me.
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 02-10-2026, 19:38.
Michael II
Post05-11-2003, 21:32    Subject: WFS Errors: Troubleshooting and Solutions Quote
Sure, here is the translation:
"The following are some possible options:"
No signal or implausible signal detected on the W-line between the immobilizer control unit and the engine control unit.
=> Check the wiring for breaks or short circuits.
The baud rate of the immobilizer control unit is incorrect.
=> Code the control unit and enter the correct baud rate.
Misuse:
After the engine stopped, the ignition was immediately switched back on (during the after-run phase).
Turn off the ignition, wait at least 10 seconds, turn the ignition back on, and then check the error memory again.
Immobilizer control unit J362 is defective.
Tschüss
Michael II
Translated on 02-10-2026, 19:40.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts 3C0-937-049-30-H Error: Troubleshooting Guide On-Board Diagnostics (OBD)
