AGR Failure Damage: 1Z Engine Problems
palmstrollo
Post06-11-2003, 18:51    Subject: AGR Failure Damage: 1Z Engine Problems Quote
Hi.
I intend to disable the AGR (Abgasrückführung) system on my Audi 80 Avant TDI, manufactured in 1/93. During a seal replacement on the flange of the intake manifold, I diagnosed a significant buildup of deposits, which indicates a considerable amount of carbon buildup. icon_eek.gif
After cleaning this, the thought occurred to me about disabling the AGR (Abgasrückführung - Exhaust Gas Recirculation).
I would install a suitable, thin, oval plate into the upper inlet directly at the manifold suction pipe.
1. Question: Is that enough?
2. Question: Are (especially negative) side effects to be expected?
Thank you.
Hermann.
Translated on 11-09-2026, 23:03.
Post06-11-2003, 19:14    Subject: AGR Failure Damage: 1Z Engine Problems Quote
Here as well, the search function will help you with both questions.
Translated on 11-09-2026, 23:04.
palmstrollo
Post06-11-2003, 19:37    Subject: AGR Failure Damage: 1Z Engine Problems Quote
@Matthias.
That's right. I had already searched, but the results were accordingly affected by typos icon_redface.gif.
Now I'm smarter (no typos); tomorrow, the AGR is closed!
Thank you and best regards.
Hermann.
Translated on 11-09-2026, 23:05.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Hands-free noise in Audi A3 (1996-2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Compressor Wheel Damage: Is It Dangerous? Diesel Engine Technology
No new posts PD Motor Problems: Common Failure Causes Diesel Engine Technology
No new posts Air Filter Upgrade Kit to Prevent MAF Sensor Damage. Diesel Engine Technology
No new posts Recognizing Early Signs of PDE/Injector Damage Diesel Engine Technology
