Tachometer Signal 1Z Engine: Questions & Troubleshooting
CB16
Post13-11-2003, 13:36    Subject: Tachometer Signal 1Z Engine: Questions & Troubleshooting Quote
I installed a 1Z engine in my 1991 VW T3 van and want to connect a gasoline-powered tachometer. There has to be a way to do it; it's been done before.
The gasoline engine tachometer from the bus receives its signal directly from the ignition coil KL.1.
Now, the TDI control unit has the tachometer output connected to pin T68/2, which is supposed to be circuit class 1.
Nothing happens when connected directly.
Does anyone know what kind of signal the TDI-STG outputs and how I might be able to convert it? The STG is from a Golf manufactured in 1993.
I hope you can help me.
Carsten.
Translated on 01-11-2026, 13:54.
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question about engine control unit from G3 ABS motor 1H09... On-Board Diagnostics (OBD)
No new posts Timing Belt Replacement: 1Z Model Questions Diesel Engine Technology
No new posts ZR Replacement: Additional Work & Costs Diesel Engine Technology
No new posts Ask the LLM about gasoline engines - which maintenance wo... Gasoline Engine Technology
