PD-TDI Engine Noise When Shutting Off
GerTDi
Post29-11-2003, 22:32    Subject: PD-TDI Engine Noise When Shutting Off Quote
Hello everyone,
'Who is familiar with the following phenomenon:'
When I turn off the engine of my AJM (Bora), I hear a noise coming from the engine compartment after about 1-2 seconds. It sounds like a compression release, a dull 'thud.'
Ist das normal oder nicht? Ich habe den Wagen seit 2 Wochen, das Geräusch war von Anfang an da. Sonst ist motorseitig alles normal bis unauffällig. Das Geräusch kommt irgendwie aus Richtung Motorblock, evtl. dahinter (von vorn gesehen). Es hÜrt sich nicht 'kaputt' an, wenn ihr wisst was ich meine. Es ist reproduzierbar und scheint irgendein Ventil o.ä. zu sein, das 2 sec nach Abschaltung irgendeinen Betriebsdruck ablässt. WeiDoes anyone have any advice?
PS: Sorry for my layman's description icon_redface.gif.
Translated on 03-10-2026, 6:19.
Post29-11-2003, 23:09    Subject: PD-TDI: Noise when engine shuts off Quote
GerTDi wrote:
When I turn off the engine of my AJM (Bora), I hear a noise coming from the engine compartment after about 1-2 seconds. It sounds like a (de-)compression, a dull "WUPP".
Is that normal or not?
.... is perfectly normal. That noise is from the bypass valve. It reduces the braking force so that the engine shuts down more smoothly.
To get a more detailed description of that part, you could try using the search function.
Translated on 03-10-2026, 6:20.
GerTDi
Post29-11-2003, 23:20    Subject: PD-TDI Engine Noise When Shutting Off Quote
'Thank you. I had already searched for 'motor' and 'noise' but couldn't find anything suitable. I'll do some more research now.'
Translated on 03-10-2026, 6:21.
Jan6K
Avatar-Jan6K
Post30-11-2003, 0:51    Subject: PD-TDI Engine Noise When Shutting Off Quote
Open the valve and take a look, especially when someone else is shutting off the engine. With an ASV (Automatic Shut-off Valve), you can observe this beautifully because the lever mechanism of the shut-off valve is clearly visible.
Jan.
1Z5 CFHF / AHB H4D
Translated on 03-10-2026, 6:22.
Post30-11-2003, 10:00    Subject: PD-TDI Engine Noise When Shutting Off Quote
GerTDi wrote:
Thank you. I had already searched for "motor" and "noise" but couldn't find anything suitable. I'll do some more research now.
That's fine.
Your description was accurate and very helpful, and you shouldn't feel embarrassed about it. As far as I remember, no one has asked that question before, so you wouldn't have found a good answer even with the search function (at least if you weren't familiar with the term "Abstellklappe").
Translated on 03-10-2026, 6:23.
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts 2.0 TDI BRT engine produces a subtle ringing noise Diesel Engine Technology
No new posts Starter motor: Noise after engine start Diesel Engine Technology
No new posts Strange noise on the AXR... Diesel Engine Technology
No new posts Noise in BMW X3 when pressing the clutch Diesel Engine Technology
