Audi Wheel Load Capacity: What You Need to Know
davidshoes
Karma: +6 / -2   Thank you, like it!
Post23-11-2003, 12:56    Subject: Audi Wheel Load Capacity: What You Need to Know Quote
Hi, a little off-topic.
For my T4, I'm planning a few modifications for the spring. I'm thinking of getting new Bilstein shock absorbers, adjusting the torsion bar at the front, installing sport springs with a -20mm drop at the rear, and adding larger stabilizer bars at the front and rear. Since the large TDI puts quite a bit of stress on the wheels, I want to get bigger ones. Instead of 225/60R16 on 7Jx16, I'm considering 235/55R17 or 18 on 8Jx17/18.
Okay, theoretically, all Audi bolt circle patterns 5x110 (?) should fit. But where can I find the load capacities? Will the ones from the A8 be sufficient? The T4 has a front axle load of 1200kg. However, the 3.3 TDI and the W12 also have this load capacity.
Translated on 03-09-2026, 14:07.
Sir Tortsch
Post23-11-2003, 20:55    Subject: Audi Wheel Load Capacity: What You Need to Know Quote
Okay, theoretically, all LK 5/110 models should fit, and you're right about that.
Okay, so my friend installed rims from the new A8 on his Passat. He was also concerned about the load capacity, so he brought a brochure from the A8 showing those rims being used. And that's how he got them approved. Regarding the load capacity.
Translated on 03-09-2026, 14:09.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts A3 Rims: New Wheels & Styles Transmission, Chassis, Body & Interior
No new posts Are 3C and 1K rims interchangeable? Transmission, Chassis, Body & Interior
No new posts Rims G3? Rolling? Transmission, Chassis, Body & Interior
No new posts Will these rims fit? Transmission, Chassis, Body & Interior
