Non-Functional Horns and Fog Lights
Paserati
Post22-11-2003, 23:43    Subject: Non-Functional Horns and Fog Lights Quote
I would like to know how to solve the following problem:
On a Passat Variant TDI (66 kW, manufactured in 1994, 1.9L engine, 245,000 km), after replacing the immobilizer, the horn and the side marker lights stopped working... it's strange that both of them stopped working at the same time.
Error memory is clear, fuses are also okay, connections are working.
Okay, the horn isn't getting any power, and the fog lights aren't working either... everything else seems to be functioning.
Translated on 12-10-2026, 22:45.
Martin R
Post22-11-2003, 23:54    Subject: Non-Functional Horns and Fog Lights Quote
What exactly was renewed by the WFS?
It's probably just a loose connection somewhere.
It's best to take another close look at the area that was disassembled.
Translated on 12-10-2026, 22:46.
Paserati
Post23-11-2003, 9:51    Subject: Non-Functional Horns and Fog Lights Quote
Hello Martin,
At the workshop, the engine control unit (ECU) was replaced because the engine shut off while driving. Since then, everything was fine... until now, except for the horn and fog lights.
'Because you said there was a loose cable... I pretty much exposed all the cables on the bike last Friday and checked everything (starting from the handlebars, through the light switch, all the way to the fuse box)... everything is where it should be. Also, the horn works when I apply power.'
CU.
Translated on 12-10-2026, 22:47.
Post23-11-2003, 10:53    Subject: Non-Functional Horns and Fog Lights Quote
Paserati wrote:
...even the horn goes off when I have enough juice.
icon_biggrin.gif icon_biggrin.gif I once spent weeks troubleshooting a similar issue on my Jetta, and it turned out to be "just" the ground cable connected to the steering gear. Perhaps a ground strap was "forgotten" during assembly.
Translated on 12-10-2026, 22:48.
Martin R
Post23-11-2003, 11:49    Subject: Non-Functional Horns and Fog Lights Quote
Perhaps the bridge or the relay (in the case of two horns) has become disconnected from the ZE (Zündanlage - ignition system).
I would continue the search there, as the 'ZE' is 'in the middle,' and that immediately tells you which direction to search next.
Unfortunately, I don't have a booking schedule for your ZE (electric vehicle). However, the following might also apply to your vehicle:
http://www.doppel-wobber.de/relais_g3.html
The relay switches the ground connection and is also controlled using the ground connection!
Translated on 12-10-2026, 22:49.
Paserati
Post26-11-2003, 15:42    Subject: Non-Functional Horns and Fog Lights Quote
Thanks, Martin! The wiring diagram for the Golf 3 is 'similar.' I was able to fix my problem.
Martin R
Post26-11-2003, 20:08    Subject: Non-Functional Horns and Fog Lights Quote
Thank you, Martin!!!! The wiring diagram for the Golf 3 is 'similar'. I was able to fix my problem.
What was it?
Translated on 12-10-2026, 22:50.
No new posts Passat 3B: Horn Not Working - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Ignition switch not working Electrical Systems, Vehicle Electronics, Multimedia
No new posts GRA Polo 6R - Non-Functional On-Board Diagnostics (OBD)
