AAT Injector Pump: Compatibility with Old ECU?
DirkC4
Post05-12-2003, 13:29    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
I'm getting a new AAT (automatic air conditioning) from a vehicle that was involved in an accident.
This is a "3rd generation" AAT --> it was connected to a control unit "0 281 001 253".
(but the control unit is not included).
Now, I want to run this engine with my "2nd generation" engine control unit, model number "0 281 001 128".
Is that possible?
Because:
I've heard that in the "3rd generation" fuel injection pumps, the slider position is no longer simply reported back via a potentiometer (G99).
but rather electronically (it is then referred to as "Position sensor for control slide (G149)").
Now, the question is whether my control unit can handle it.
see also here ...
Please provide the text you would like me to translate from German to English.
Translated on 13-10-2026, 20:54.
Rudi
Post05-12-2003, 14:12    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Hello Dirk,
The old STG probably still has those nasty icon_cool.gif 257's latch EPROM's.
The newer one already has 'standard' 512-unit components (its internal structure is roughly similar to an MSA12).
I once tried to run an old AAT with a new control unit.
Fortunately, nothing died.
However, it didn't work either. The entire problem was then...
but it was not pursued further, as it was easier to modify the existing STG.
Best regards, Rudi.
Translated on 13-10-2026, 20:56.
DirkC4
Post05-12-2003, 15:09    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Rudi wrote:
I once tried to run an old AAT with a new ECU.
It couldn't have worked because the pin configuration is different --> see the link above...
Translated on 13-10-2026, 20:57.
diesel.gustav
Post08-12-2003, 1:40    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Deleted upon request.
Translated on 13-10-2026, 20:58.
DirkC4
Post08-12-2003, 9:18    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
@diesel.gustav:
Hey, that's a reasonable statement, thanks!
And couldn't one install inductive feedback into an old pump (or vice versa?)??
Should I send you the files through a different method if you're unable to download them?
Rudi
Post08-12-2003, 11:33    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Hi Dirk,
At the time, I didn't have those lists, and (apart from the signaling system controller),...
Are the differences significant enough to be implemented in software?
Gustav can tell you whether the pump replacement is mechanically possible on an HDK.
probably says; but - why don't you just swap the control unit (and the wiring harness)?
Even the modifications to the existing wiring harness should be feasible with relatively little effort.
replace (two lines and possibly a few connectors - HDK?! - with others).
Best regards, Rudi.
Translated on 13-10-2026, 21:00.
DirkC4
Post08-12-2003, 11:45    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Rudi wrote:
... but - why don't you swap the control unit (and the wiring harness) ? ...
Because I won't be receiving a 3rd generation control unit with the new engine... icon_cry.gif
(but it is also in my first post... icon_wink.gif )
Furthermore, what are you doing about the immobilizer (WFS) and some other modifications?
(Is an external WFS control unit and a transponder reading head required in the ignition switch?)
Translated on 13-10-2026, 21:01.
Rudi
Post08-12-2003, 12:27    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
Hi Dirk,
You can usually find TDI engine control units (ECUs) on eBay for around 100 EUR.
WFS: In T3/T4 conversion areas, the wiring harness is being tampered with somewhere along its length.
(complete with the donor key) and never touched again.
You can also find these items on eBay (I bought a WFS-STG with a reading spool there).
(Paid 15 EUR for the key).
If you're lucky, you might occasionally find a newer TCU (Transmission Control Unit) without the WFS (Wireless Function System).
(hacked or prototype ECUs).
Best regards, Rudi.
Translated on 13-10-2026, 21:02.
DirkC4
Post08-12-2003, 23:10    Subject: AAT Injector Pump: Compatibility with Old ECU? Quote
diesel.gustav wrote:
Hello Dirk C4,
Take a look at the pumps on the engines if you can.
The older "Potipumpe" has the fuel return line pointing straight upwards from the actuator cover.
The newer "HDK pump" has the return flow oriented horizontally towards the back. This is a clear way to distinguish it from other models.
and here's another example to illustrate:
Pump "old":
Bosch: 0460 415 988
VAG: 046 130 108 A
http://www.24max.de/audi-documents/motorschaden/einspritzpumpe_alt.jpg
Pump "new":
Bosch: 0460 415 989
VAG: 046 130 108 G
http://www.24max.de/audi-documents/motorschaden/einspritzpumpe_neu.jpg
Translated on 13-10-2026, 21:05.
diesel.gustav
Post09-12-2003, 0:17    Subject: SEO: Exactly what I meant Quote
Translated on 13-10-2026, 21:06.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injector: Repair or Replace for 2.5 TDI? Diesel Engine Technology
No new posts Fuel Injector Control Unit 2.5 TDI On-Board Diagnostics (OBD)
No new posts Injector Pump Control Unit Pinout Diesel Engine Technology
No new posts VAGCOM Adapter: From Old Cable to New Use Diesel Engine Technology
