LMM (Pierburg) cleaning
Ferdi
Post03-12-2003, 15:55    Subject: LMM (Pierburg) cleaning Quote
Hello everyone!
This is my first post on this forum, and the topic has already been extensively discussed, but I still have a few questions!
Therefore, I have read quite a few posts on this topic and have become much wiser as a result.
Ulf had in his LMM tuning topic visually represented Pierburg, and I noticed that on the engine side, the filter had been removed. Does that make sense? Perhaps regarding advantages related to flow?
My LMM (air-to-air intercooler) from my Golf 4 TDI AHF 81 kW is fortunately equipped with the thick Pierburg unit, and so far, with approximately 190,000 km, it hasn't caused any problems, except for gradually decreasing maximum speed, a lack of power in the middle speed range (2000 - 3500 RPM), and increased fuel consumption!
Okay, LMM expanded and, lo and behold,
is really dirty and I'm going to clean it now.
I was thinking about trying to use cleaning spray from electronics (Kontakt Chemie) instead, since brake cleaner is quite aggressive. What do you think about that?
On the engine side, I carefully removed the filter to better spray the sensor.
Should I reattach the protective screen?
Let's see if it works, I'll report back!
Best regards, Ferdi
Marco
Post03-12-2003, 16:30    Subject: LMM (Pierburg) cleaning Quote
Hi Ferdi,
I would definitely re-install the filter. From a flow perspective, there shouldn't be any measurable difference. However, I'm surprised that your filter was so dirty. Have you driven with a sports air filter or even without any filter at all?
Bububaer
Post03-12-2003, 16:52    Subject: LMM (Pierburg) cleaning Quote
My dad also cleaned his (sudden acceleration on the highway).
He cleaned it with degreasing benzine. By the way, it's also a Pierburg.
After cleaning, it was like new.
Good luck
Bubu
Ferdi
Post03-12-2003, 16:55    Subject: LMM (Pierburg) cleaning Quote
Hello Marco
I've left the grid on the air filter side, but I removed it on the engine side!
Ich denke darüber nach, Kurbelgehäuseentlüftung, vielleicht dient das Sieb als grober Ölabscheider, um den Sensor nicht direkt zu verstopfen. icon_question.gif
Regarding your question about... Sportlufi, everything is original!
It just has 190,000 km on the odometer, although when I bought the car a year ago with 150,000 km, the cover behind the air intake of the headlight was missing, meaning the engine was sucking air from the engine bay icon_exclaim.gif icon_exclaim.gif
Just wanted to briefly report that I have cleaned the LMM (Manifold Absolute Pressure Sensor) and have noticed a significant increase in performance. Also, the Vmax (maximum speed) of 200 km/h is easily achieved!
Fuel consumption, I'll just have to wait and see.
Regards, Ferdi.
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Pierburg 1.9 Tdi Tandem Pump Diesel Engine Technology
No new posts Pierburg: Troubleshooting & Diagnostics Tips Diesel Engine Technology
No new posts Pierburg MAF Sensor: Now Officially for TDI Engines Diesel Engine Technology
No new posts Pierburg MAF Sensor Failure: Troubleshooting Diesel Engine Technology
