RPM and "Glow Coil" in Basic Settings
Post05-12-2003, 15:11    Subject: RPM and "Glow Coil" in Basic Settings Quote
HI.
I searched for "000 speed basic," but I only found Rainer's article, which doesn't answer my question.
I once dared to try the "basic settings" in channel 000 of my Z series device.
It immediately started to rev up slightly, and the MSTG indicator light began flashing.
After completing the "Basics" phase, both phenomena had disappeared.
Is this behavior normal for this mode, or does it indicate a problem? (As far as I know, the engine was still too cold for a complete fuel injection start diagnosis).
Thank you.
m
By the way, it only gets to 81 degrees Celsius, at least that's what it was after half an hour of testing (I haven't completely reviewed the data from the 90-minute test run yet).
Translated on 16-08-2026, 2:51.
Post05-12-2003, 15:22    Subject: RPM and "Glow Coil" in Basic Settings Quote
dieselmartin wrote:
I once dared to try the "basic settings" in channel 000 of my 1Z.
Is this normal for the mode, or does it indicate an error?
Hi Martin,
It seems normal to me.
The engine speed shouldn't really increase, but the full retarded timing gives it a slightly different sound (as long as the timing isn't already at its maximum retarded position when idling).
Perhaps you perceived it as a higher speed?
Translated on 16-08-2026, 2:53.
Post05-12-2003, 15:29    Subject: RPM and "Glow Coil" in Basic Settings Quote
I thought I recognized it from the DZM.
But is the glowing blinking correct???
When reading out the airbag and ABS systems, their respective warning lights also come on.
I'm going to take the basic test again tonight, so I can pay closer attention this time.
"m" translates to "male" in English.
Translated on 16-08-2026, 2:55.
Post05-12-2003, 15:31    Subject: RPM and "Glow Coil" in Basic Settings Quote
dieselmartin wrote:
But is the glow-blinking correct???
The engine computer only has the glow plug light on, and during the basic settings, it's programmed to blink. Everything is okay icon_wink.gif.
Translated on 16-08-2026, 2:56.
Post05-12-2003, 15:36    Subject: RPM and "Glow Coil" in Basic Settings Quote
Okay, understood.
It only surprised me that when simply CHECKING the airbag and ABS systems, they visually indicate something is wrong, while the engine only reports tampering with BASIC functions. icon_smile.gif
Thank you.
Translated on 16-08-2026, 2:57.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed "frozen" at ~1200 Diesel Engine Technology
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
