TDI Audi 80: Replace Crankshaft Position Sensor?
palmstrollo
Post04-11-2003, 18:20    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Hi.
Before I go any further: I used the search function -- but I didn't become very knowledgeable icon_redface.gif.
Here's the translation:
'The timing belt on my Audi 80 Avant TDI, manufactured in January 1993, with engine code 1Z, needs to be replaced soon. It goes without saying that the tensioner and other related components will also be replaced. But what about the central bolt for the crankshaft? The previous owner had the timing belt replaced at an Audi dealership in Italy. The invoice does NOT show a new central nut. Thanks to the search function, I now know that the tighter bolts have a ring-shaped protrusion on the bolt head. If, during the replacement, it turns out that the tighter bolt (12.icon_cool.gif is already installed, does it still need to be replaced, or should it be left untouched? If the 'softer' bolt is still in place, it will definitely be replaced. Did Audi issue a recall for this issue? If so, the crankshaft bolt should have been replaced by then, especially during the last timing belt replacement (at the Audi dealership in Italy), right?'
So: Should you replace a screw if it's hard or not? icon_question.gif
Thank you and best regards.
Hermann.
Translated on 19-10-2026, 11:44.
didl
Post04-11-2003, 19:08    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Hello.
'Personally, I would definitely replace that screw!'
The screw has already come loose on mine, and it was already the 'heavy-duty' one that was installed!
Translated on 19-10-2026, 11:45.
golf3schrauber
Post04-11-2003, 19:27    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Is it also a good idea to check the screw between the timing belt replacement intervals?
Perhaps try tightening the screw?
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 19-10-2026, 11:46.
didl
Post04-11-2003, 19:37    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
It definitely makes sense to do that, especially if you already know it's a weak point! And checking things never hurts, right?
I probably wouldn't follow up.
palmstrollo
Post04-11-2003, 19:41    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Was ist mit Audi? Was ist mit einem Rückruf bezüglich dieses Problems? If so, and if the 'soft' screw is still in use, can one still insist on having this action performed?
Are there any opinions on whether it's advisable to replace a 'hard' screw that might already be installed as part of the belt replacement?
Okay, here's the translation:
Thank you.
Hermann.
Translated on 19-10-2026, 11:47.
didl
Post04-11-2003, 19:56    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Translating...
[Translating...]http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
palmstrollo
Post04-11-2003, 20:07    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
@didl.
I was already familiar with that. Does this work instruction also apply to Audi? Also, this work instruction refers to the soft screws.
I'm concerned about whether a potentially existing, hard, completely solid, and 'non-leaking' screw should also be replaced. The fact that the cost is negligible, at just under 2 Euros, is really secondary. It's not comparable to the cost of a valve, a head of lettuce, or a complete engine failure. icon_razz.gif
Hermann.
Translated on 19-10-2026, 11:48.
chris11
Karma: +3 / -1   Thank you, like it!
Post05-11-2003, 13:59    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
"There's a 12.8-grade screw in there, and everything seems solid, so I wouldn't do anything. If you absolutely have to remove the washer, do it with the Allen screws. Disassembly won't improve the situation, and either you have sufficient contact pressure, in which case everything will be fine, or you don't. If you don't, it's only a matter of time before something goes wrong."
In Formula 1, they use ultrasound devices to measure the tension of screws even after they've been tightened. Maybe you have good connections with Schumacher or Montoya.
Christian.
palmstrollo wrote:
@didl.
I'm concerned about whether a potentially existing, hard, completely solid, and "non-leaking" screw should also be replaced. The fact that the cost is negligible, at just under 2 Euros, is really secondary. It's not comparable to the cost of a valve, a head of lettuce, or a complete engine failure. icon_razz.gif
Hermann
Translated on 19-10-2026, 11:50.
lofthouse
Post04-12-2003, 21:26    Subject: Replace Expansion Bolts: Best Practices Quote
Since the central bolt is a stretch bolt, it should always be replaced.
A stretch bolt is almost always pre-tensioned with a specific torque and then tightened to a specific angle of rotation.
Translated on 19-10-2026, 11:51.
donalexo
Post04-12-2003, 22:43    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
@lofthouse:
While your statement about stretch bolts is technically correct, there is no need to replace the central bolt of the crankshaft pulley during a timing belt replacement. If anything, only the bolt on the camshaft sprocket is usually loosened.
BTW, this is also much easier because even a hobbyist mechanic can achieve the correct torque for this screw, even after a very poor breakfast icon_biggrin.gif.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 19-10-2026, 11:52.
haehnlein
Post06-12-2003, 20:09    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
donalexo wrote:
Even a hobbyist who hasn't had a good breakfast can easily achieve the correct torque for this screw icon_biggrin.gif
Hi Alex,
Well, I needed a lot of force, and I'm not exactly weak http://www.smiliemania.de/smilie.php?smile_ID=280. Even my long 3/4-inch breaker bar from Hazet didn't significantly reduce the required force. Furthermore, the screws that are standardly installed in the VW 3099 tool tend to bend. These also need to be replaced with high-strength 12.9 screws (-> e.g., brake caliper screws).
____________
Kein Auto mehr!
Translated on 19-10-2026, 11:54.
christians
Post06-12-2003, 21:10    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Simple question: When replacing the timing belt on the 1Z or other four-cylinder engines, can the vibration damper be left in place? On the 5-cylinder engines, it seems it has to be removed, probably because there's a cast-on protective element underneath the pulley. (I haven't done this myself yet).
Gruß Christian
Translated on 19-10-2026, 11:55.
WarLord
Post07-12-2003, 15:11    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
Since I will soon be facing the issue of timing belt replacement myself: How is it done on the 1Z engine? What steps do I need to perform? I think the tools will be less of a problem, considering what I saw in Dieselmartin's other thread.
Best regards, WarLord.
D. Kurz
Post08-12-2003, 9:39    Subject: TDI Audi 80: Replace Crankshaft Position Sensor? Quote
@Christians
The vibration damper needs to be removed; there's no other way, because otherwise you won't be able to remove the lower part of the timing cover. I'm probably going to get some criticism for this... but if you have a really good 6mm Allen key socket, not some worn-out one, and the 4 screws also look good, then you can use a hammer and an impact driver to easily remove the screws. Unfortunately, the vibration damper itself is quite stuck on the timing sprocket, because the inner part is made of aluminum and the sprocket is made of cast iron – contact corrosion. Caramba and a carefully used pry bar can help.
Dominique.
Translated on 19-10-2026, 11:56.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Replacing control arm bushings on an Audi 80 TDI Transmission, Chassis, Body & Interior
No new posts Properly tightening the KW central screw in the AKE? Diesel Engine Technology
No new posts Replace ZR on AKN Yourself? Diesel Engine Technology
No new posts Rack and Pinion Steering Replacement Audi A4 Transmission, Chassis, Body & Interior
