Where can I get genuine chip guard compound? / How can I obtain original chip guard compound?
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post17-06-2004, 20:44    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
My Polo also fell backwards off the jack today, but with the wheels still attached.
I straightened the bent lifting arm again, but due to the extreme pressure during the "rolling off" over the side edge of the lifting arm, a piece of this rubber-like stone guard was torn off.
I initially covered the bare metal with an underbody sealant spray, but this relatively soft material will likely get pushed aside again when I jack up the car normally next time.
So, I could reapply the sealant each time – or repair the area with that rubber-like substance that comes from the factory. The latter would be much preferable for me.
Does anyone here know where to find this and how it's processed?
Translated on 11-07-2026, 7:47.
Julian
Post17-06-2004, 20:48    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
It's regular black Teroson adhesive, just in this particular container. It's applied using an 'air gun' at the factory, and also by professional workshops.
For home users, it's also available in spray cans, which are good for small repairs; you should apply several coats.
Translated on 11-07-2026, 7:49.
Post17-06-2004, 22:08    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
Julian wrote:
It's regular black Teroson adhesive, just in this specific container. It's sprayed on at the factory using an "air gun," and it can also be applied by a professional workshop.
Für den Heimnutzer gibts das auch in Spraydosen, für so kleine Reparaturen auch gut, man sollte halt mehrere Lagen auftragen.
The Teroson that I know (and have in spray cans) doesn't form a rubber-like layer that can be stretched to approximately twice its length before it tears... instead, it only adheres to the surface without having the "internal toughness" of the original coating.
It's also roughly the color of clay on the inside, while Teroson is black...
But if even workshops use "only" Teroson as a replacement for the factory coating, then I probably have to limit myself to that as well icon_sad.gif.
Translated on 11-07-2026, 7:50.
Gerrit
Post17-06-2004, 22:37    Subject: sprayable body sealant Quote
hello,
You should check with automotive accessory shops for sprayable body sealant. (I'm thinking of companies like Förch or Normfest, although that might be too much advertising.) I've had good experiences with it; the result is a rubbery substance. If appearance isn't critical, I think you can apply this stuff with a brush. If it's important, I can gladly provide the exact name (manufacturer and order number).
Best regards, Gerrit.
Translated on 11-07-2026, 7:52.
Back to top Profile PM Email
delvos
Post18-06-2004, 12:45    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
However, the jack will keep pushing this stuff away again and again.
After my first visit to the workshop with my current car (the car was less than 3 months old), they lifted it using a hydraulic lift *without* rubber pads. You can probably imagine what it looked like afterward. Everything was crushed down to the bare metal.
They also sprayed some professional-grade stuff on it back then (after I had already gotten everything dirty, the first comment was "it's nothing, it's galvanized," which almost made me explode).
The coating peeled off the first time I tried to apply it. Since then, I've been spraying a clear wax on after each "application," which has the advantage of preventing any unwanted buildup. The metal itself is still fine.
Translated on 11-07-2026, 7:54.
Post18-06-2004, 12:48    Subject: Subject: sprayable body sealant Quote
Gerrit wrote:
wenns wichtig ist kann ich gerne die genaue bezeichnung ( hersteller und bestell nr) nachliefern.
Hi Gerrit,
Translated on 11-07-2026, 7:55.
Gerrit
Post20-06-2004, 1:28    Subject: flexon Quote
hello,
You can get this product from the company Normfest under the name Flexon (order number 28933).
Have fun. Gerrit.
Post20-06-2004, 10:56    Subject: Re: flexon Quote
Gerrit wrote:
hello,
du kannst das zeug bei der firma normfest unter der bezeichnung flexon ( best nr 28933 ) bekommen.
Hi Gerrit,
Thank you for the information.
I found a suitable website at www.normfest.de, but it doesn't list any distribution channels or products.
Do I find these parts at general auto parts stores, or do they have special distribution organizations?
Translated on 11-07-2026, 7:56.
WarLord
Post20-06-2004, 12:46    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
Just give them a call. Maybe they can send it to you too.
Best regards, WarLord.
Translated on 11-07-2026, 7:57.
Post04-07-2004, 15:18    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
WarLord wrote:
Why don't you give them a call? Maybe they can also send it to you.
I initially tried looking for it at local auto parts stores.
They don't have a standard color chart, but one person checked the Teroson color palette and found something labeled "Terolan light."
While it's technically marketed as a body sealant, the product description reads very similarly to that of the factory-installed stone chip protection.
I then bought a cartridge of the product, and indeed: after drying, the color and consistency are practically the same as the original material from the factory.
Let's see how this stuff behaves when the jack has to be used again...
Translated on 11-07-2026, 7:58.
Post04-07-2004, 22:16    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
Besides the hydraulic jack, I always use a stable board that is 30x30 cm in size as a support under the car. So far, no underbody protection has ever come loose from it.
If something happens due to ground contact or other issues, I simply apply a thick layer of roofing bitumen (used for sealing roof felt). I usually have a bucket of it around, and if there's no rust underneath that stuff, then there never will be icon_smile.gif.
Kost also lau und reicht ewig das Zeug. Bei nem Neuwagen tuts aber trotzdem etwas weh Bitumen zu verwenden... icon_cool.gif
Translated on 11-07-2026, 8:00.
Post05-07-2004, 17:49    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
Rainer K. wrote:
Besides the hydraulic jack, I always use a stable board that is 30x30 cm in size as a support under the car. So far, no underbody protection has ever come loose from there.
It's already clear, but I was referring to the built-in jack and its few square centimeters of unpadded new_tomato.gif metal contact surface icon_evil.gif.
Translated on 11-07-2026, 8:01.
DocSnydor
Post06-07-2004, 9:02    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
'I always have a piece of rubber or something like that... (an old bicycle tire works well). It just can't be too thick.'
Translated on 11-07-2026, 8:02.
Post06-07-2004, 20:53    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
DocSnydor wrote:
Da hab ich immer ein Stück Gummi oder so... (alter Fahrradreifen geht gut) Darf halt nicht zu dick sein.
I've been looking for a icon_idea.gif. I'll take a look around, thanks for the tip!
BigB
Post07-07-2004, 8:05    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
Hey everyone,
I'm risking being called a clueless newbie and getting flamed for using SDI and my rather unconventional repair method, but here's my solution.
My carpool companions have a habit of complaining about every bump in the road, no matter how often they've ridden in the car before.
Okay, so let's get to the point. I'm going with Hammerite, specifically the black version, although any color should probably work. Don't laugh, but it protects against rust, prevents the spread of any existing rust, and is actually quite durable, even against abrasion. But I think most people are familiar with the advertising for this product.
Best regards, BigB.
Translated on 11-07-2026, 8:03.
Julian
Post07-07-2004, 8:39    Subject: Where can I get genuine chip guard compound? / How can I obtain original chip guard compound? Quote
I use Hammerite, the hammer finish black, although any other color tone should also work. Don't laugh, it protects against rust, prevents the spread of any existing rust, and is actually quite durable, even against abrasion.
There is no effective way to combat rust other than replacing the affected parts. While products like Hammerite are decent, they only convert the rust into iron phosphate, which will continue to corrode over time. However, because of its thick consistency, Hammerite can sometimes mask the underlying corrosion, making it appear better than it actually is. Therefore, I wouldn't recommend using it for car repairs, sorry!
Translated on 11-07-2026, 8:05.
No new posts Wo bekommt man Nadelhubgeber günstig? Diesel Engine Technology
No new posts VAG-COM adapter not getting power! On-Board Diagnostics (OBD)
No new posts Kraftstoffabschaltventil (ALE) bekommt kein Signal. Was nun? On-Board Diagnostics (OBD)
No new posts ot: wo bekommt man größere mengen kaltreiniger günstig Diesel Engine Technology
