avoso Guest
05-04-2004, 19:39 Subject: Audi A2 central locking, no confirmation |
I recently bought an Audi A2. When locking/unlocking using the remote key, there is no confirmation, such as a short beep or the hazard lights flashing.
Is this function not supposed to be available on the A2 model?
Thank you in advance, and best regards.
Okay, here's the translation:
Achim.
mersente Guest
05-04-2004, 20:49 Subject: Audi A2 central locking, no confirmation |
Hello, you can turn the blinking or honking feature on or off in the comfort control module.
matthiasTDI96 Profi-Schrauber
06-04-2004, 14:18 Subject: Audi A2 central locking, no confirmation |
It's also possible that some of the door contact switches aren't working correctly. So, if a door on my Golf/Passat isn't closed properly, nothing will light up. Since this function is enabled by default (blinking), I suspect there might be a problem with the door electronics. Could there be a control light illuminating in the A2 area, or is there a display showing something?
AND
Does the red LED in the driver's door blink after locking with the remote control?
avoso Guest
06-04-2004, 16:31 Subject: Audi A2 central locking, no confirmation |
Hello and thank you for your replies!
According to the error memory of the comfort control unit, there is no error present! How can I activate the horn/turn signal function?
Achim.
mersente Guest
06-04-2004, 20:55 Subject: Audi A2 central locking, no confirmation |
Unfortunately, I can't determine that this week because I'm on vacation. Perhaps someone here knows more, otherwise you'll have to wait until after Easter.
avoso Guest
07-04-2004, 16:30 Subject: Audi A2 central locking, no confirmation |
Okay, just don't stress out!
Thank you in advance, and have a lovely Easter celebration!
Achim.
Cheffe Blaumann
10-04-2004, 15:05 Subject: Audi A2 central locking, no confirmation |
You can check it out yourself if you have a VAG 1551 or something similar.
To do this, go to the comfort control unit (address word 46), then select "adjustment" (10), and then select channel 8 (-> flashes when unlocking) and channel 9 (flashes when locking). Value 1 enables the function, and 0 disables it.
Boss.
avoso Guest
12-04-2004, 12:38 Subject: Audi A2 central locking, no confirmation |
Hey boss,
Thank you for your reply!
Unfortunately, that didn't help me either. 'I'm only getting the message 'Channel 8 is not available'!'
I've also made changes to the central locking system on other VW/Audi vehicles, but something seems different about the A2!
Does anyone else have any ideas about what might be causing this?
Thank you and best regards.
Achim.
