Tinting the rear window of a Volkswagen Golf IV
RaZoR
Post10-06-2002, 10:48    Subject: Tinting the rear window of a Volkswagen Golf IV Quote
Hello everyone!
I would like to get the rear window of my Volkswagen Golf IV tinted with silver film.
Does anyone have any tips on what I should be aware of?
-What kind of soap solution do I need (distilled water?)
- Does the rear door trim need to be removed? If so, how is it done?
-Does the film need to be cut into multiple pieces (the Golf IV has a slight curvature to the windows)? If so, what overlap is required?
Thank you in advance.
Razor.
Translated on 11-07-2026, 20:44.
D.
Post10-06-2002, 17:21    Subject: Tinting the rear window of a Volkswagen Golf IV Quote
Hi!
I'm not really sure, but apparently there will be an article about window tinting in the next issue of 'Auto Bild,' which is coming out next Saturday.
Maybe this will help you.
Best regards, D.
Translated on 11-07-2026, 20:45.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Wiper Nozzle: Fixable & Replacement Guide Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
