"These rims only come with the original center caps designed for the Passat 35i. I also had those on my GTI. At least they properly cover the hub and bolts. However, you have to be careful, as 4-hole and 5-hole designs are not interchangeable."
They weren't particularly expensive in 1996, but of course, that doesn't necessarily mean anything for 2003
You could also try using aftermarket hubcaps. Most of them are designed to be quite large, so they tend to fit a wide range of vehicles. We bought some for our Polo 9N after the dealership wanted a whopping 86 euros (!) for a set of hubcaps, and even eBay was asking almost as much for used ones.
I found that the caps at the Gl*bus hardware store were well-made for a very reasonable price of €2.29. They have a metal ring, and the only thing I noticed was that the paint was a bit thin. But hey, for the money we saved, we can buy new ones every winter for years to come...
